Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 136 guests, and 10 robots.
Topics128,281
Posts1,058,470
Members48,490
Silly me did not notice this till now. I have a quarter size hole just a couple inches above the vent on the passenger side. What was this used for?
Antenna? It would be side mounted just one hole
1953 chevy 3100
No telling what a previous owner did. The proper place for an antenna on my 52, and I figure your 53 is up on "top" of the cowl. Maybe they used one of those swivel antenna bases for side mounting?
It's most likely a hole for the antenna.
My 46 GMC on Photobucket
Yes, I have the same hole in the same place. The antenna was not installed, but I can send you a picture of the antenna if you need it.
yes please send pic -
thinking it may be like a beetle anttena
ebay beetle Antenna
Here is what I have. It was not installed when I got the truck so I don't know if it original or not.
Antenna 1
antenna2
Here is a photo of a NOS radio with antenna. The original mounts up on the drivers side cowl in a very precise location for hood clearance.
http://www.flickr.com/photos/advance-design_parts_co/8129324957/in/set-72157631868452754
There is significant discussion on this topic if you search in the Radio Forum.
Well Brad, I guess that answers my question if it is original or not. In case it helps, here is the position of the hole on my 58.
Hole for antenna
Ted, Brads AD is very different than the TF radio/antenna - the antenna you have is common aftermarket - yours should be mounted in the fender directly below where the hole you show is .... see here
Ted sorry I did not catch the year more closely.
The mirror mounts in about that location, but there should be 2 holes
Cleon
OOPS! I thought I read 1/4 inch hole. I see now it is a quarter size hole.
1949 Chevy 6400
1931 Chevy Firetruck
Sorry for the confusion Brad. After seeing your material Bill, and Brad's picture, I can see mine is incomplete aftermarket junk. I will patch that hole before I paint.
