| | | Forums66 Topics128,102 Posts1,056,532 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Silly me did not notice this till now. I have a quarter size hole just a couple inches above the vent on the passenger side. What was this used for?
Antenna? It would be side mounted just one hole
1953 chevy 3100 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | No telling what a previous owner did. The proper place for an antenna on my 52, and I figure your 53 is up on "top" of the cowl. Maybe they used one of those swivel antenna bases for side mounting? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It's most likely a hole for the antenna. | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Yes, I have the same hole in the same place. The antenna was not installed, but I can send you a picture of the antenna if you need it. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | yes please send pic - thinking it may be like a beetle anttena ebay beetle Antenna
| | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Here is what I have. It was not installed when I got the truck so I don't know if it original or not. Antenna 1 antenna2 | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Well Brad, I guess that answers my question if it is original or not. In case it helps, here is the position of the hole on my 58. Hole for antenna | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ted, Brads AD is very different than the TF radio/antenna - the antenna you have is common aftermarket - yours should be mounted in the fender directly below where the hole you show is .... see hereBill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Ted sorry I did not catch the year more closely. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The mirror mounts in about that location, but there should be 2 holes Cleon OOPS! I thought I read 1/4 inch hole. I see now it is a quarter size hole.
| | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Sorry for the confusion Brad. After seeing your material Bill, and Brad's picture, I can see mine is incomplete aftermarket junk. I will patch that hole before I paint. | | |
