1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | I looked through 20 pages of posts and didn't see anything about this. Does anyone know where to get the correct door hinge pins for an AD truck. I ordered them from LMC and they sent 1 size fits 47-89 that are entirely to big. The hinge holes measure approx 0.310" and the pins I got are 0.345" diameter. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I'd be buying me a new drill bit and maybe truing up the hinge guides which are probably worn out too... but You could no doubt keep searching for or have a 0.310" made if that seems like a bother
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Pins are sold oversize because most hinges are wallowed out and they would not fix the wear issues. I found my driver side as expected severely worn while my passenger side was in pretty good shape. There is plenty of meat on the hinge to drill the holes to match your pins. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think most hinge pin holes began at about 11/32 and as Brad says the new replacement pins are a few thousandths bigger. Check out the tech tip about rebuilding hinges. I think there is a tip on just the pin and a tech tip on rebuilding them using the brass bushings. Good luck. Let us know how you make out. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Marcus,i've just been through this using the LMC pins on my '50,like the guys say most hinges have considerable wear after 60+ years.
Rebuilding them with the oversize pins and brass bushes worked well for me and the drivers door now latches with a satisfying clunk. Just a point though,replace the springs while your at it too,they're cheap to buy and make a big difference.
Like yours the passenger side was much better so I opted to leave it alone for the meantime. I'm a firm believer in "if it aint broke,don't fix it!"
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | I bought what I hope is the right size drill bit today. I was kind of assuming what I've heard called the hinge 'bar' is hard as flint. I found a youtube video of a guy who was drilling em out to rebuild them and he didn't use the brass bushings. Is it better to use them? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I found a youtube video of a guy who was drilling em out to rebuild them and he didn't use the brass bushings. Is it better to use them? I suppose it depends just how worn the hinges are Marcus,but the idea of the brass bushes is that they then become the 'wear' surfaces rather than the pins themselves. Initially I wasn't going to use them but in the end i'm glad I did. Bear in mind it's taken your hinges 60+ years to get the state they're in so I imagine it'll be a long time before they would need rebuilt again. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | 60 more years? I'll be 90 by then. I plan to still be driving this truck. lol | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | 60 more years? I'll be 90 by then. I plan to still be driving this truck. lol I didn't realise you're just a young 'un.....  Good man! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 43 | If 30 = youngin then I'm guilty as charged. When you get to be 30 you start to like it when they ID you at the, um, uh, that place where they require you be 21.
I got the passenger hinges drilled, bushings installed, and re-assembled. As I said earlier I was expecting that hinge bar to be hard steel. In fact, it's about like drilling through butter. | | |
