2 members (JeffA, Mike B),
167
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Besides taking off the hoses and electrical, does the glove box or anything else have to be taken off to get to the heater core on a '62 c-10. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | nope not that I'm aware of. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | If it is the Thrift-Air heater, you can replace the core from under the hood. I did one a few years ago in a 1966 C-10, and it only took about a half hour | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | What Doug said. You should be able to get it done without having to go under the truck and stand flatfooted on the shop floor. Hardest part is getting the little bitty screws lined back up to hold the blower motor back n place. Try marking their locations with a marking pen for reference. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | dunno if you have the same setup or not... '65 c10 - heater some other links there that may come in handy, as well. -W | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Something to check before you pull out your heater ...
I removed and installed the heater in my '54 three times before I figured out that it was leaking because my heater hoses were off-size. Water leaked where they joined the pipes to the core and ran down the pipes into the heater case, then onto the floor. The ID was larger than 5/8". I could easily tell when I poked my finger into one of the hoses, then did the same to a new hose. Dunno if the hose wallowed out over time or if it was always too large.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Something to check before you pull out your heater ...
I removed and installed the heater in my '54 three times before I figured out that it was leaking because my heater hoses were off-size. Good point... I had a similar issue with a water hose on my truck when I first got it. -W | | |
