3 members (Bill Hanlon, DadsFirstPickup, Otto Skorzeny), 75 guests, and 2 robots.
Topics128,154
Posts1,056,840
Members48,456
Besides taking off the hoses and electrical, does the glove box or anything else have to be taken off to get to the heater core on a '62 c-10.
nope not that I'm aware of.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
It depends..... thumbs_up
What type of heater do you have?
Check out this link: http://67-72chevytrucks.com/vboard/showthread.php?t=488618
If it is the Thrift-Air heater, you can replace the core from under the hood. I did one a few years ago in a 1966 C-10, and it only took about a half hour
What Doug said. You should be able to get it done without having to go under the truck and stand flatfooted on the shop floor. Hardest part is getting the little bitty screws lined back up to hold the blower motor back n place. Try marking their locations with a marking pen for reference.
dj durant
More pix on Flickr
Socket Breaker
Socket Breaker
dunno if you have the same setup or not...
'65 c10 - heater
some other links there that may come in handy, as well.
-W
Something to check before you pull out your heater ...
I removed and installed the heater in my '54 three times before I figured out that it was leaking because my heater hoses were off-size. Water leaked where they joined the pipes to the core and ran down the pipes into the heater case, then onto the floor. The ID was larger than 5/8". I could easily tell when I poked my finger into one of the hoses, then did the same to a new hose. Dunno if the hose wallowed out over time or if it was always too large.
- Lonnie
My '54 3104
Socket Breaker
Socket Breaker
Good point... I had a similar issue with a water hose on my truck when I first got it.
-W
