7 members (Otto Skorzeny, Rusty Rod, baldeagle, dt235sd, Woogeroo, Hotrod Lincoln, Bill Hanlon),
356
Mod | | | Forums66 Topics128,165 Posts1,057,086 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Looks like someone fabricated them special, I don't believe that they are OE. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "all original body"? the truck has obviously been 'restored', do you have some documentation that's the way it came from the factory? have you checked the date codes on everything to see if it was an early or late build? you do know all the 'cab/chassis' models came with short running boards? can't quite tell from the pic, but it looks like the back part of the board is smooth, not ribbed like the front part or like a 46, I really doubt the factory would have sent out a make shift like that when they'd already held new models back for months Bill | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | Thanks for opinions & replies. I am certain this is all original factory steel. The truck has been in the local area since new. I did paint the truck, but did not change any body parts. I know GM made half running boards for some larger truck options. The back halves of the running boards are ribbed and match the front sections exactly. The sections bolt together and are all steel. I pulled the 216 for a 235 and no longer have those numbers, also the truck is in storage and not sure I have manufacture date codes. It’s obviously an unusual truck but others must exist somewhere.
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I was going to say perhaps it was originally a platform or stake bed which had the short running boards ending at the rear of the cab but according to my 1948 Restoration Guide, at least, Chevy didn't offer those for 1/2-ton trucks. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | I did find another image, which might better show the matching running board sections and splash apron. Also notice how the running board contours to fit under the back of the cab. The hump near the fender is for the rear leaf spring . [IMG] http://i1291.photobucket.com/albums/b542/RdLessTaken/RdLessTaken%20Trucks/IMG_76612_zps673cb617.jpg[/IMG]
Last edited by RdsLessTaken; 02/10/2013 6:01 AM. Reason: Link to photobucket error
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | A good body/metal man could make the running boards and apron pretty easy. Perhaps long before you bought it. JMO
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I am certain this is all original factory steel. I'm even MORE certain it's NOT. Nice fabricating though.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a real low ID number on the vin would be an indication it was early production
"Also notice how the running board contours to fit under the back of the cab." which the factory did not do on any year - and the outside edge contour doesn't appear to match well - there's just way too much "custom fitting" for that to have been factory, even for a one-off proposal, prototype, or "quick, fake something because the real boards aren't ready yet"
if that was factory you have a totally unique truck, now you need to find the proof positive it wasn't some later add-on, even by a dealer "finishing" a truck shipped "incomplete" or later adding a bed to one shipped as a cab and chassis, which would have had short boards
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | do you have a pic from under the running board at the seam between the two pieces. | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | Sorry guys, you can never convince me this is not a genuine all factory built truck. I know a local farmer purchased it new and parked it beside his barn after many years use considering it worn out. After his passing it was again purchased locally then sold to some kid who painted it red, - chrome trim and all. None of the previous owners had money or talent to do bodywork or fabrication on the truck. It still had the worn out 216 engine, center pull park brake, non-working gauges, everything original. A plastic gas container & rubber hose served as missing gas tank. It was a rat’s nest with a $50.00 red paint job when I bought it about 15 years ago. This truck is not a fabrication by the owners. A dealer creation when new seems unlikely to me but who knows. http://i1291.photobucket.com/albums/b542/RdLessTaken/img5851_zps5e273334.jpg | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | Re:DADS50 "do you have a pic from under the running board at the seam between the two pieces." Sorry, I do not have a pic of that on hand nor easy access to the truck to get one today. Both sections of the running boards have the usual one inch or so downturn lip around the bottom. The sections were bolted together where they joined. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Don,
Forgive us doubting Thomases. We are very used to people who have trucks about which they are sure everything is original (usually because they were told that by people in the family, or by the seller).
I was also going to chime in with a chuckle, but I first checked the 1947 Chevrolet Truck Data Book Advance-Design Models. This would have allowed me to assure you that no odd running-board option was available on 1947 3104 (1/2 ton pickup) trucks.
However, I am pleased to report that there was an Option No. 389 in 1947 for only the 3104 model: Wide Running Boards, " . . . ideal for newspaper or other types of jumper distribution." I'll try to scan a photo. The illustration does not show a seam, but it is not a photo and the artists took liberties back then.
Just chill out and smile smugly.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Tim, YOU DA MAN! You always seem to find the cool info to prove or disprove a thing.
Sure would like to have a set of those boards for my ride. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I want to say I saw one with the same option on ebay a month ago.
Congrats on your rare option,these guys are tough sometimes.
Is the spring hanger under the running boards ?
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | This is a pretty rough crowd, one would think I claimed to own a UFO.. When it is obviously just a pretty rare truck.. ;-) Yep, the spring hangers are under the humps in the running boards with “leaver actions” up front.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Can you post some pictures of underneath,I'd like to see what it looks like.
These guys are usually 99.9 percent friendly,It's Friday Eve and probably a full moon out tonight.
Keep posting questions and pictures,because everyone learns something new everyday.
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bowtietim has it right. We're here to learn....and I learned LONG TIME AGO not to jump to conclusions. You should read some of the stuff that came out of "detroit" and a lot of it is just now surfacing. They also made a lot of "pushers" back then just for show. I'm intriqued and want to know more! Oh, and I've also learned another lesson in life....NEVER say NEVER!!! Rdslesstaken, hang in there. I like it because it's unique.
Tim, looking forward to a pic when you can. No rush. | | | | | Joined: Mar 2000 Posts: 1,183 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,183 | I looked at those pics several times wondering where the wide part was. I compared it to mine, which is a '48. My truckThen I realized, it's the part behind the cab. To make it wider they flattened the splash apron and added more running board on the inside. That's the reason for the bulge to clear the spring mounts. Pretty cool, but I'm wondering why a farmer would order that option? | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | for your farm hand to ride on?
i know you could set the throttle cable to idle faster/slower if you wanted, so you could put your 4 speed in 1st and hop out, walk next to it, toss bails in the back, wakling next to the truck, and then hop on your extra wide step and ride? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... now you need to find the proof positive it wasn't some later add-on .... not such a rough crowd, just insistent  so now you know you don't have some unique model, but a rare option, and have the documentation to prove it Bill | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | Thanks to everyone, and special thanks to tclederman for the documentation, and to bowtietim for seeing another trunk with this rare option on ebay. Unfortunately I cannot get more pictures anytime soon. The truck is in storage for the winter and the guy storing will not be back until spring. I will probably be able to post more images then if anyone is still interested. The guy storing it has also decided to purchase the truck. We have all learned something new, I believed it might be an early “transitional “ truck using left over running boards and apron from ’46, but we now know wide running boards was “factory option No. 389”. Thanks again for the info. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'm thinking this piece is of very high quality and complex in it's fit and form, gotta be factory. There were many odd ball bodies/boxes and beds available back then, set up for all kinds of uses. First off I'd keep this as is, it fit's to nice and a great conversation piece. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Wow! Congratulations on having the rarest option I've ever seen.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Sure,we all want to see more pictures. You're stuck with us stovebolters now !!!
| | | | | Joined: May 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 51 | Nice Truck, Running Boards Stock or Not.... | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | very cool running boards , now i want a set ! if i would have seen a set at a swap meet or junk yard i would have thought they were custom made also .
| | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | how much are these running boards worth ? i would like to get a set | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | RE: big dan 1950 I have no idea what these optional running boards might be worth or how few might still exist. I can only say I have never seen another pair. Perhaps bowtietim can give us an idea of their value as he recently saw a similar set or truck for sale on ebay. Don/RdsLessTaken http://s1291.beta.photobucket.com/user/RdLessTaken/library/RdLessTaken%20Trucks
| | | | | Joined: Apr 2011 Posts: 50 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 50 |
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Must admit I have seen/owned a lot of AD's but this is the first two of these. Pretty cool. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have no clue what they sold for.I didn't put them in my watch list and I wasn't sure if they was the real deal.
we do like pictures,so keep posting them.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for the pic's.  | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | RE: 485WINDO Congratulations and a fraternal handshake! Thanks for more photographs (evidence). We now know there are a least two trucks with this running board combination still in existence. I hope to be back with more pictures of "Option No. 389" in the spring when I can get access to the locked away green '47. Don/RdsLessTaken http://s1291.beta.photobucket.com/user/RdLessTaken/library/ | | | | | Joined: Apr 2011 Posts: 50 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 50 | Hey Don , Maybe this makes our trucks worth millions !!  | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Just goes to show you (me) that there are still things to learn about these old trucks. Very Cool. Thanks.
Keep on truckin'!!
Professional Novice
| | | | | Joined: Mar 2011 Posts: 11 New Guy | | New Guy Joined: Mar 2011 Posts: 11 | your 47 is a rare truck, there were very little made. dont sell it, nice and original. just because their were very little info or no info doesnt mean it doesnt exist. good luck
IDAHO
