1 members (Hotrod Lincoln),
129
Mod | | | Forums66 Topics128,275 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Disassembled the front bumper assembly for blasting and painting. Beating some of the sheet metal in to shape.
Fitting and tacking up the exhaust.
Thinking about running my tail light wiring. | | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Went to install my radiator that came in today but of course Its not the right one dose not fit. Now return Wait for it to be shipped back out. So I hung tailgate put in rear lights and redid break line flares. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Sandblast the front bumper brackets, painted said parts.
Got out the tig to 1) Practice welding with it and 2) Finish welding the exhaust pipes. Not a bad outing but need much more practice!! | | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Bluemeanie that has a great stance to it now. MNSmith what kind of tig welder do you have best welder once you get the hang of it make beautiful passes little distortion | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Miller Syncrowave 250. I should probably start practicing on flat stock and not tubing. Not a hard concept, just got to learn to finesse it and synchronize foot with hand and hand. I didn't do real bad with the exhaust tubing and O2 sensor bung. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I took my burb for a spin with after dropping in another 235, swapping the 3rd, with a 3 speed with over drive on the tree now.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Bluemeanie that has a great stance to it now. Thanks!  | | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | I discovered my dash has been attacked by an angry beaver. Sad what people can do to an old vehicle. Site of Beaver Attack A PO had this metal flange plate to cover the damage. Not a bad idea but could have been executed better. metal flange This is the radio I took out. Can anyone ID it for me. RadioHope to remove speaker grill tomorrow. But it is cold here and the truck is outside.
1952 Chevy 3/4 ton 1948 Simplex Motorcycle 1930 Ford Model A Coupe 1928 Ford Model A Station Wagon
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My dash looked like yours so I smoothed it and painted. I don't listen to the radio in any vehicle so it's no loss to me. I, too, have to do all my work outside in the elements. | | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | Your dash looks good.
I assume you welded in some sheet metal and then some bondo.
What color did you paint your dash?
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I rolled a piece of 18 gauge steel at work to match the dash, so it needed almost no bondo. Then I used Rust-oleum's Dark Bronze Metallic (#7272). It's a decent match for the original color, but I wanted some shine so I used Rust-oleum's Crystal Clear Enamel (#7701) over the bronze. It looks better in person, and in the sun. | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Peg here. Have I told you lately this is a most excellent thread!  Peg
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2013 Posts: 20 New Guy | | New Guy Joined: Jan 2013 Posts: 20 | put in a new rear main seal (roap seal) got the pan cleaned up and ready for paint should the pan be painted black or the blue-gray like im going to paint the rest of the engine what do yall think? Dirk
dbum
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Pan is same color as the rest of fhe engine. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ....well, even though I don't feel to chipper today I had my son help me put the PVC cowl cover inside the cab on my panel today. I wish I had put it in earlier but we got r done. I just need to replace the gas pedal and couple small things like putting some self tapping screws through it to keep it in place. I filled all holes when the body was off for body work.
....it was a little tight and had to trim the edges a little but with all the cowl panel work its no wonder. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Pulled my rad out, also the fan and water pump. I sourced a bigger pulley for the water pump, will change that on Monday, heater going in too while the engine is drained. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | With the holidays over I'll be heating the garage and diving into a few chores I've been planning on for a couple of months. The first is to locate a remote charging station to avoid having to remove carpet of drop the battery when needed. If my fading memory will allow I'll post some pics.
~Jim
| | | | | Joined: Dec 2012 Posts: 3 New Guy | | New Guy Joined: Dec 2012 Posts: 3 | Starting to order a few parts as we work on the IFS. Discovered we needed to order some new T-bolts to attach the A-arms since we're using some existing parts we already had. Also ordered my column saver kit, which I'm quite excited about! Plan on keeping my interior as original as possible but have a more dependable engine. So looking forward to getting a few boxes from my FedEx man at the end of the week!
Ella Newman 1950 Chevy Half Ton
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I disassembled the heater from the '59 and sanded, primed and painted the housing. The blower motor is siezed though... I'm hoping the '58 parts truck has a good one. I also freed-up the throttle and choke cables and painted some interior parts since it was sunny yesterday. I'm waiting on a Fed-Ex delivery as well... new glove box liner and bumpers, heater decal and a firewall grommet set. I only had a few hours to "play" but any progress is good. The turn of tide for some reassembly is near! Jerry
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Starting to order a few parts as we work on the IFS. Discovered we needed to order some new T-bolts to attach the A-arms since we're using some existing parts we already had. Also ordered my column saver kit, which I'm quite excited about! Plan on keeping my interior as original as possible but have a more dependable engine. So looking forward to getting a few boxes from my FedEx man at the end of the week! I can relate to the excitement of expecting parts from Fed-x and UPS. That is one of the "fun" things (watching for the delivery) we experience in this hobby.
~Jim
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ I love that feeling  | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Got the 454 painted, doghouse off the truck, a few dings beat out of the grill ( how the heck do the grills get dinged up behind that big bumper anyway ). Will be pulling the 235 and 4 speed out this week and mocking up the big block and Clark 5speed OD by the weekend. Its gonna be a whole new animal! | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Sandblasted the rear apron, beat it into a better shape. Beat the front apron in to a decent shape. Tomorrow, more welding of the cracks then finish blasting the front apron, then paint for both. I'm still pulling glass bead out of my ears. Work might slow on the Suburban again as it is almost time to put the flopper together! Gonna need to fix and update the trailers for both the flopper and the dragster! Meanwhile, I'm getting the itch to start wiring the Suburban. It would be really cool to use it as a push car in March!! | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Finally got the new fuel pump installed. Then I let it run for a half hour and shut it down. Next step is to change the pinion seal. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | my truck has a 70 Nova 10 bolt under it.So far I've installed axles bearings and seals,new brake shoes.New axles and wheel studs are next | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | Welded and painted said aprons. | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | Added blinkers to my marker lights | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | took the engine out last night and started cleaning, painting and all the other stuff that goes with "refurbishing" an engine  Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I finally got a bigger pulley on the front of the waterpump. The 6" pulley simply went over the existing 4" pulley. Bolt the fan back on, get a slightly longer fan belt and I'm in business. I did a short road test and I smiled all the way. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | The 6" pulley simply went over the existing 4" pulley. Won't this move the pulley about a hundred thousands forward and cause a slight misalignment of the belt resulting in excess wear?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The 6" pulley simply went over the existing 4" pulley. Won't this move the pulley about a hundred thousands forward and cause a slight misalignment of the belt resulting in excess wear? Just what I was thinking.
~Jim
| | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | I haven't had the mental wherewithal to do anythng since October...divorce and all. Gotta get back to it! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Staying busy, the cure to mental stuff.
~Jim
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | The 6" pulley simply went over the existing 4" pulley. Won't this move the pulley about a hundred thousands forward and cause a slight misalignment of the belt resulting in excess wear? Just what I was thinking. Not worried about that at all. She runs great! | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Sep 2010 Posts: 1,736 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,736 | It's looking good. Any response from law enforcement as to who did it? Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
