0 members (), 133 guests, and 4 robots.
Topics128,186
Posts1,057,211
Members48,465
Page 82 of 177 1 2 … 80 81 82 83 84 … 176 177
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Disassembled the front bumper assembly for blasting and painting. Beating some of the sheet metal in to shape.
Fitting and tacking up the exhaust.
Thinking about running my tail light wiring.
Went to install my radiator that came in today but of course Its not the right one dose not fit. Now return Wait for it to be shipped back out. So I hung tailgate put in rear lights and redid break line flares.
Lowered the '51 back in November. Just now got around to uploading the pics and updating my blog.
http://rustyfiftyone.com/2012/11/18/attitude-adjustment-ol-girl-is-at-an-all-time-low/
Also replaced the shocks and the axle came from a fellow bolter who had already replaced the kingpins. Man, what a difference the whole shebang made!
Sandblast the front bumper brackets, painted said parts.
Got out the tig to 1) Practice welding with it and 2) Finish welding the exhaust pipes. Not a bad outing but need much more practice!!
Bluemeanie that has a great stance to it now.
MNSmith what kind of tig welder do you have best welder once you get the hang of it make beautiful passes little distortion
Miller Syncrowave 250. I should probably start practicing on flat stock and not tubing. Not a hard concept, just got to learn to finesse it and synchronize foot with hand and hand. I didn't do real bad with the exhaust tubing and O2 sensor bung.
I took my burb for a spin with after dropping in another 235, swapping the 3rd, with a 3 speed with over drive on the tree now.
Thanks! cool
I discovered my dash has been attacked by an angry beaver. Sad what people can do to an old vehicle.
Site of Beaver Attack
A PO had this metal flange plate to cover the damage. Not a bad idea but could have been executed better.
metal flange
This is the radio I took out. Can anyone ID it for me.
Radio
Hope to remove speaker grill tomorrow. But it is cold here and the truck is outside.
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
My dash looked like yours so I smoothed it and painted. I don't listen to the radio in any vehicle so it's no loss to me. I, too, have to do all my work outside in the elements.
Your dash looks good.
I assume you welded in some sheet metal and then some bondo.
What color did you paint your dash?
1952 Chevy 3/4 ton
I rolled a piece of 18 gauge steel at work to match the dash, so it needed almost no bondo. Then I used Rust-oleum's Dark Bronze Metallic (#7272). It's a decent match for the original color, but I wanted some shine so I used Rust-oleum's Crystal Clear Enamel (#7701) over the bronze. It looks better in person, and in the sun.
24601
24601
Peg here.
Have I told you lately this is a most excellent thread!
smile
Peg
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Big Bolt Forum Co-moderator
metal flange
Radio
I had a small job like that over the driver side window where someone had put in an overhead wiper. It was an easy patch.
http://i527.photobucket.com/albums/cc355/Chevytwoton/interior%20patch/IMG_7661.jpg
Cut out the crap.
http://i527.photobucket.com/albums/cc355/Chevytwoton/cutoutfordriversidepatch_zps7e4f5918.jpg
Then welded in a new patch. I just had to bend it with my vise and blocks of wood if I remember correctly.
http://i527.photobucket.com/albums/cc355/Chevytwoton/driversidepatch_zpsa7cd9f4a.jpg
Should have had the camera on macro, sorry for the fuzzy pics. Very little bondo.
1948 Chevy 2-Ton
put in a new rear main seal (roap seal) got the pan cleaned up and ready for paint should the pan be painted black or the blue-gray like im going to paint the rest of the engine what do yall think? Dirk
dbum
Pan is same color as the rest of fhe engine.
....well, even though I don't feel to chipper today I had my son help me put the PVC cowl cover inside the cab on my panel today. I wish I had put it in earlier but we got r done. I just need to replace the gas pedal and couple small things like putting some self tapping screws through it to keep it in place. I filled all holes when the body was off for body work.
....it was a little tight and had to trim the edges a little but with all the cowl panel work its no wonder.
Leo Offline
Moderator
Moderator
Pulled my rad out, also the fan and water pump. I sourced a bigger pulley for the water pump, will change that on Monday, heater going in too while the engine is drained.
With the holidays over I'll be heating the garage and diving into a few chores I've been planning on for a couple of months. The first is to locate a remote charging station to avoid having to remove carpet of drop the battery when needed. If my fading memory will allow I'll post some pics.
~Jim
Starting to order a few parts as we work on the IFS. Discovered we needed to order some new T-bolts to attach the A-arms since we're using some existing parts we already had. Also ordered my column saver kit, which I'm quite excited about! Plan on keeping my interior as original as possible but have a more dependable engine. So looking forward to getting a few boxes from my FedEx man at the end of the week!
Ella Newman
1950 Chevy Half Ton
I disassembled the heater from the '59 and sanded, primed and painted the housing. The blower motor is siezed though... I'm hoping the '58 parts truck has a good one.
I also freed-up the throttle and choke cables and painted some interior parts since it was sunny yesterday.
I'm waiting on a Fed-Ex delivery as well... new glove box liner and bumpers, heater decal and a firewall grommet set.
I only had a few hours to "play" but any progress is good. The turn of tide for some reassembly is near!
I can relate to the excitement of expecting parts from Fed-x and UPS. That is one of the "fun" things (watching for the delivery) we experience in this hobby.
~Jim
^ I love that feeling cool
Got the 454 painted, doghouse off the truck, a few dings beat out of the grill ( how the heck do the grills get dinged up behind that big bumper anyway ). Will be pulling the 235 and 4 speed out this week and mocking up the big block and Clark 5speed OD by the weekend. Its gonna be a whole new animal!
Sandblasted the rear apron, beat it into a better shape. Beat the front apron in to a decent shape. Tomorrow, more welding of the cracks then finish blasting the front apron, then paint for both. I'm still pulling glass bead out of my ears. Work might slow on the Suburban again as it is almost time to put the flopper together! Gonna need to fix and update the trailers for both the flopper and the dragster! Meanwhile, I'm getting the itch to start wiring the Suburban. It would be really cool to use it as a push car in March!!
Finally got the new fuel pump installed. Then I let it run for a half hour and shut it down. Next step is to change the pinion seal.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
my truck has a 70 Nova 10 bolt under it.So far I've installed axles bearings and seals,new brake shoes.New axles and wheel studs are next
Welded and painted said aprons.
Added blinkers to my marker lights
took the engine out last night and started cleaning, painting and all the other stuff that goes with "refurbishing" an engine grin
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Leo Offline
Moderator
Moderator
I finally got a bigger pulley on the front of the waterpump. The 6" pulley simply went over the existing 4" pulley. Bolt the fan back on, get a slightly longer fan belt and I'm in business. I did a short road test and I smiled all the way.
Won't this move the pulley about a hundred thousands forward and cause a slight misalignment of the belt resulting in excess wear?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Just what I was thinking.
~Jim
I haven't had the mental wherewithal to do anythng since October...divorce and all. Gotta get back to it!
Darren
1969 Chevy C-10 Fleetside
Staying busy, the cure to mental stuff.
~Jim
Leo Offline
Moderator
Moderator
Not worried about that at all. She runs great!
http://i1296.photobucket.com/albums/ag6/ecratrods/greenrims_zpsa7c64f94.jpg
Well its a long process but I am getting there thanks to all my fellow bolters.
Changed the oil.
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
back yard wrench turner
It's looking good. Any response from law enforcement as to who did it?
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
