| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I am trying to adjust my steering box and can not get the worm bearing thrust screw to turn. I have loosened the lock nut. I do not want to mess up the slot, and everything I have seems too small. I need a giant flat blade tip or something. My manual shows a particular tool for this, some type of large blade to fit in the slot, that will attach to a ratchet. Can anybody steer me in the right direction for the proper tool??
Much thanks.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used a large cold chisel and a box end wrench on the handle. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I welded a flat piece of steel the right thickness to an old socket. Works good.
Chuck | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That adjustment is almost never needed to be changed once set. Play is almost always between the pitman and the worm nut. If the pitman shaft bushings are bad you will never get a successful adjustment. That adjustment is on the side cover.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree with Dave, that adjustment is a ball bearing adjustment made at the time of assembly. If it's loose then you wouild need to replace the ball bearings or best look for another gear. Any slop in the steering gear should be taken up by the pitman shaft adjusting screw. CAUTION: Move the gear thru it's full range after adjustint the shaft to make sure there are no tight spots.
Denny Graham Somewhere north of Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | My manual shows a weight tool on steering wheel to adjust to 1 to 1 1/2 lbs pull what other tool could be used (fish scale) ? Is this necessary? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I use a fish scale, works just fine. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Look for a set of drag link sockets, they work great. Ditto on the fish scale.
Jeff | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Help me out here guys, where did you find a fish scale that is accurat enough to measure 1 to 1 1/2 lbs.???? All of them that I found are totally in accurate when you get down to a couple of lbs. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 |
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lonnie,
You probably have a cookie on your PC that takes you to a specific part. All I get is the Sears home page. What is the part number?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What about this one, Denny. I got my spring 10b fish scale at Walmart about 10 years ago. I do not know how well calibrated it is, but the improvement in the steering was remarkable. Yamato T-10 | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tim - Sorry about the Sears link. I posted the link from my iPhone while I standing in line at the movie. Here's another source.> pic: Rapala / Normark Rapala Digital Fish ScalesThe Sears site says ... Sold By: FishUSA, Inc. Item#: SPM5835854203 Model#: RMDS50 I don't know how exact the pull-measurement has to be. I used my fish scale when I adjusted my steering box, but also used a little Kentucky windage, too. Bottom line - my steering is tight and the truck is a pleasure to drive vs. the quarter-turn play that it had before I adjusted. 'Course my steering wheel is now a quarter turn to the right and one of the spokes blocks the gas and oil pressure gauges.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, yeah, that's what I mean guys, there taint a good one out there. Tim and Lonnie, I think you guys know by now that I just like to stir things up a bit to stimulate some conversation. Actually I've went thru this many years ago. The problem with a hanging scale is the higher the capacity the less sensitive and less accurate they are at the lower end. The ideal scale for this sort of measurement would be a 0 to 5 lb. hanging scale but no one makes one of those. Oh yes, Tim, that postage scale you posted the link to is only good to 4oz. This is a Rapala 15lb. scale that I found a few years back after a lot of searching. It has a pretty good feel down at the lower end. But in the real world I think what the engineers at GM were trying to define for us was that we should just feel a slight drag in the gear when we turn the wheel. The 1-1 1/2lb. preload spec is just some way of defining that you need just a touch of drag. http://www.pbase.com/dennygraham/image/147721999 Denny Graham Somewhere north of Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | If you have a decent torque wrench with the beam rod on it, you can read the difference in torque as you cross center. The actual measurement is not that critical, you are just looking for slight difference and a little pull.
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | South Bend 8-Pound PS-8 Pocket Scale Available at K-Mart for $4.08 (also available on-line and at Amazon.com) | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I used my RCBS trigger pull gauge, 8 oz to 8 lbs. They can be had for around $20. Then you can go check the trigger pull on all of your firearms!
Kent | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | and just where would one find one of those Tim, not on my internet.
Denny g
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Besides in K-Mart, Denny, on-line for $1.88, and $1.81, and $4.54 on eBay, and $4.52 (on Amazon), and $2.00 (Farm & Fleet), try this search: PS-8 pocket scale south bend | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ah yes, helps to get the name right Tim. I was looking for a "PS-4" because the picture was to blurry to read the number correctly. Should have dawned on me that if it was an 8lb. scale it would logically have an "8" in there somewhere.
Taint worth $12 shipping for a $1.81 item, but I do have three Blain's F&F stores all within 20 miles of me and I'm in one or the other at least once a week.
Tks, Denny G.
