Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 116 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
Page 80 of 177 1 2 … 78 79 80 81 82 … 176 177
Looking good thumbs_up
~Jim
Originally Posted by mobileortho
Got the headliner, door panels and LED dome light installed
Nice results
Do you have power windows?
Looks GREAT. I expecially like the chevy emblem in the door panel...
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Yesterday I adjusted the valves in my 1950 3600 (235) (they did not seem that far off and everything looked very clean)
I also replaced my heater switch with a new one fron NAPA. The old one only worked on high speed. I've taken it apart and found it to not be repairable. $16.99 later, the new one works great. High speed then a slow delcine in speed AND the light buld works and dims as the speed reduces. I think that is how is supposed to work!
I'm still driving it as the bed metal and rear fenders are in body shop prison! The rest of the truck will make it to body shop in a bit.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
Originally Posted by DADS50
Nice results
Thanks. My attempts at adding power windows were epic failures! I could never get them adjusted right so I eventually gave up.
Robert C.
I'm a Genius in the making.
1950 3600
Nice results
Thanks for the warning Robert.lol
~Jim
Finally the dash is back togeater and I can move on to the next project. We re-built 3 of the 4 hinges and pitched the 4th into the trash. The hinge pin was just too rusty and wouldn't press out.
Here's pictures of the dash:
http://s783.photobucket.com/albums/.../?action=view&current=dash12312B.jpg
http://s783.photobucket.com/albums/.../?action=view&current=dash12312A.jpg
http://s783.photobucket.com/albums/...t/?action=view&current=dash12312.jpg
and here is the build so far:
http://s783.photobucket.com/albums/...pick%20up%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Major accomplishment for me yesterday when I removed the '59 cab from the frame.
Saturday, I constructed a dolly for the cab then made a swivel beam to be used with my engine lift.
I removed the windshield and rear glass to help lighten the load (they were coming out anyway). I then removed the steering column/gearbox assembly for a straight shot with minimum lift.
The cab came off nicely without a problem at all and is sitting pretty in my garage on the dolly. yahoo
I had a nice shower and glass of red wine afterwards... grin
'52 1/2 ton: Got the rear end gear change/rebuild completed and button up. Modified new parking brake cables and installed. New rear drums completed and new brake piping done on rear axle. Rear of chassis completed.
I installed a new master cylinder and booster. (set up and test fit with steering column). Soontake apart to paint firewall. Started on driverside rear fender.
We would sure like to see what you're doing. "Where are the pic?"
~Jim
Here is photo of my restored rear axle (with higher gear ratio installed), new brakes and brake piping...
Restored rear axle
Now that looks good, clean and deliberate. Nice work David.
~Jim
Small step on my '59 project I know, but any step forward for me is good... I painted my brake and clutch pedal arms and put the new pads on them.
There's such a feeling of gratitude knowing that every part on this truck will get my attention. I'll be at a loss when everything's done!
Two new U joints, rear tranny seal, oil and filter change, grease, and a new muffler.
Next project, '51 flatbed clutch, oil change, tuneup, brakes, and anything else it might need,
After taking the 64' on it's road trip to OKC(600 miles round trip) I got home and realized that the steering box was leaking bad. Replaced the seals on that and now it's clean and working as it should again. Didn't realize how much I'd miss having some oil in the box until I got home and found out just how tired I was after 600 miles of "Armstrong" power steering. Have some more small parts coming later this week and it's getting closer to being "DONE". For real! I've posted some pictures on Flickr but don't know if I've done it right yet to access them here. Had a great trip and looking forward to making another to Georgia in Feb. perhaps.
Tramp
dj durant
More pix on Flickr
Since 1 of the front brake calipers was hanging up I replaced both of them. Yesterday I fixed the oil leak on the SBC. There is a NTP plug in the block back near the distributor which allows the oil gallery to be drilled for the pressure sensor. In it's previous life some nimrod had jammed a 3/8-16 plug into a 1/4-14NTP hole. nono
The glass in the drivers door cracked a couple years ago so I took the glass out so I can get a new one cut next week.
It wasn't today but was this past Monday. I painted the 51. My new glass will be here Monday so I will have plenty to do next week. Pictures are in my sig below album #2.
Ok I have been working the night shift 7pm-7am going to the shop from there and finishing up a few tubs for customers. I have not had a chance to doing anyting last 2 days. But I am making great progress thanks to all you who have been helping out. I am still overwellemed with the blessings you all have made this alot more feesable. I have 4 more night shifts then I have a couple of days off I will post lots of pics on progress. I also have to find out how to post something like an album. Shawn
back yard wrench turner
Repaired my muffler after blowing out the seam from a fuel explosion in the exhaust. http://i30.photobucket.com/albums/c...deo/Waynes%20truck/Waynestruck002-18.jpg
Here is the repair as my grandfather would have done it.
http://i30.photobucket.com/albums/c...deo/Waynes%20truck/Waynestruck003-13.jpg
He would be proud! smile
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I had a foot stomp starter rebuilt and will be going in this week,its probably going to take me a little time to get used to a foot stomp starter but a 37 is supposed to have it.
completed brake booster/MC, proportioning valve and front brake plumbing installation. Still have rear brake plumbing to do, but ran out of tubing. Will take about 35' of tubing total when complete.
Brakes
Now that's ingenuity!
Looks like what might have happened back when we would cut the key off and then on for a few seconds while driving by some unsuspecting folks and causing a near heart attack.
~Jim
You GO Wayne! LOL
Well, my gallon of POR15 came in yesterday!
I'm getting stoked about this light I'm beginning to see at the end of the tunnel.
To me nothing looks worse on a truck than when the bed looks unlevel across the tailgate. Mine has a 1/2" drop on the right side, probably due to uneven springs, and it's been driving me crazy. I plan, now that I have a bit of time, on putting a 1/2" plate under my left side shackle. That should fix the problem.
~Jim
Jim, I'd suspect the cab mounts.
Cletis,
I tried the mounts with no success. I took it out to Sachse Rod Shop and Frank said It was not uncommon for a pair of springs (in this case TCI) to be built a bit different so that one set will sit lower or higher than the other. It was his suggestion to use the plate under the shackle.
~Jim
..been messing with my e-brake system for sometime. It was something I DREAMED up while laying in bed some time ago.
I hooked an adjustable "turnbuckle" type deal to the brake crossmember then ran the cable up just beneath the body under the seat riser. Ran the cable through an eyebolt that I bent to a "L" shape so it'd stick up through the floor and put a nut on it. Then bolted the e-brake from a Colt beside my driver seat.
I know I've mentioned this before but can now say it works really nice.
Just a shot where it connects. Will get shot of the handle later.
http://i140.photobucket.com/albums/r19/LutherParris/EmergencyBrake001_zpsaa838512.jpg
Seasons Greetings All you Stovebolt Builders
My 39 STUBBED TOE
I have been going out to the shop most every day & some at nite. Long hours & it's getting cold. My cab is on rollers in the shop & P30 1 ton frame just outside. Frame is to long to get inside & no rear axle under it yet. But things are looking up, I found a rear end today.
In this past week I got most of the paint/rust off the cab's exterior . One more day with my angle grinder sanding disk should do it.
Most all the hanging metal is off, one more door & a few small door sil plates to go.
Also I replaced the front coil springs with air bags this past week. Aired up with wheels & tires up front now.
Today I found a 1 ton rear end & brought it home. It's a late 1980's ford, I won't use it in the end, but I can get the frame off jack stands & rolled up to the garage door, once I have four wheels/tires on board.
Tomorrow I will be cutting the GM wheels center hub hole bigger to mount wheel to ford axle. But that's OK, they are 16.5s & I planned on scraping them anyways. I got the full set for 10-bucks, two with tires. I did need to envest another $15 each for two more junk tires, Owell, I mounted them my self, saved another $10 each. Every body wants my money.
Hopfully by Monday I can give another update on my rear end instalment.
I also took the leaf springs off frame this past week. all except main leaf.
Now to mount rearend & start seting up rear bags... WOOPEE
I can't slow down now, things are just starting to get good.
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
Just picked up a 427bbc and an Eaton Fuller 5speed overdrive to wedge into my 1.5ton. time to dig in!
Finished the rolling chassis complete with new brakes (disks up front and power assisted). Started on cab sheet metal repair and will be rebuilding engine when I need a break from sheet metal work.
Pics? Where are the pic? pix
~Jim
I stripped the dash components out of the '59 cab and began hand sanding all the surface rust.
I could only laugh at the gunk on my face when I quit for the day and saw myself in the mirror. I had a nice white area around where my dust mask fit.
Still have more sanding to do...
Finished the wiring for the blue LED's in the engine compartment. They came out really good. the picture doen't do it justice.
http://s783.photobucket.com/albums/...=view&current=enginelights121712.jpg
I also found this neat bottle up at Summit Racing to use as the reservior for the windshield washer fluid.
http://s783.photobucket.com/albums/...=view&current=washerbottle121712.jpg
John drive
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I really like the washer bottle John. Do you have pictures of how you mounted the spray nozzles?
~Jim
On the '59 the wiper bezels are pre-plumbed for the sprayer. All you have to do is remove the screw and screw in the nozzel, then connect the hose to the tube on the back side. Then I mounted a universal pump under the dash.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
"Bella" went to the sign company for graphics today to have signage put on for our country store - she'll be done tomorrow! Wahoo!!
Larry Bear
55.5 Chevy 3100 Panel
I fabricated new front brake lines and installed. Found an OEM 1953 rear axle on Craigslist and will pick it up on Sat.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Removed front and rear leaf springs to get them re-arched. Going to Houston for Christmas and found a spring shop 3 miles from where I grew up. I will take them with me. They will re-arch all 4 for $300.
Also rented a ball joint press (BIG C-clamp) to remove the spring bushings from the frame. About 3/4 turn and then heard a 'pop'! sweet sound. After that they all came out fairly easily.
1951 Chevy 3100
