Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Peggy M, tclederman, ranchojuan, greenie-reddy, 1 invisible), 160 guests, and 6 robots.
Topics128,289
Posts1,058,583
Members48,492
Page 73 of 177 1 2 … 71 72 73 74 75 … 176 177
Continued fitting the sound deadener pads and started fitting the heat insulation on the floor,firewall and roof,ran out of glue though.
All we need now is some heat so I can 'test' it!
Just waiting for my new gas tank to arrive......
More pix on Flickr.
Originally Posted by Olblue3600
Changed the oil in Olblue.. really needed to be done so I put in 10W-30 as the local stores didnt have the standard SAE 30... It feels good to have clean oil in there but my hunch is the lower viscosity will smoke more at start up..
If you have a 216/235 in there, NAPA on Watson sells Hicks Collector Car or Muscle Car Oil (same stuff) w/ZDDP additive. I buy a case of 20/50 every other oil change.
I welded in the passenger door patch panel then ground it out and used filler for finishing. It looks GREAT!
Sand, prime, paint and assembly is next.
I also met a buddy yesterday who had a driver door with no dents and minimal rust on the bottom. It's MUCH better than mine. We worked out a deal and the door's now in my garage.
I scored BIG for the '59 project this past weekend!
After a very successful first visit to Jim Carter Truck Parts and Harbor Freight tools I installed a new Tach and replacement passenger door handle assembly in 58 Suburban. Also tightened up the oil pan bolts in an effort to solve a leaking problem. All in all it was a great day!!
Larry
After having the truck for the last 25 years, I finally got my brother to send me the paperwork to put the truck in my name. I've been bugging him to send it to me for about 20 years and I finally got him off his *. Since the plan is to get the old girl back on the road by Jan 1st after 15years in mothballs I wanted to get the title straightened out.
Thanks for the tip on the oil.. I replaced the valves, guides and seals a couple years back so I didnt think it would leak down.. but I'm getting blue smoke at start up and my wife says I smell like Olblue.. well it aint all bad
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
Re-sealed my windshields and mother nature is currently water testing them and the cowl seal! (Thunderstorm)
I'll be willing to bet there's a fair few wives of guys here will agree about 'us' smelling of old truck when we come in from the garage. grin
More pix on Flickr.
back yard wrench turner
Cleaned painted and installed the front bumper.
bumper
I'm proud of how the driver side fender turned out compared to when I got it.
before
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Big Bolt Forum Co-moderator
Looking good. How did your roof come out? I see that you had quite a dent in the original shot. I have been working on my roof of my 48 and I'm not to where I want to be with it.
1948 Chevy 2-Ton
The roof still has dents and wrinkles but not caved in like before.
It sits so high I can't see it without standing on a stool. smile
Wayne
1989 Silverado
I like it! thumbs_up
1948 Chevy 2-Ton
I'm in a final sanding stage of the '59 passenger door patch panel installation.
I'm excited that soon, I can sand and prime the door interiors to apply my interior paint colors and assemble all the hardware!
Cut the original front bumper off yesterday and installed a better condition MBC stamped replacement along with a pair of stainless bumper guards. Also installed one of the original fog/tractor lights on the rear as a back-up lamp and finally did the headlight bucket gaskets, stainless trim rings and seals, and stainless visors.
Pictures - http://rustyfiftyone.com/2012/08/22/ol-gurl-gits-a-make-over-fun-stuff-pt-vii/
Chased down some rattles in the 37,I need to find spring clamps for the front springs and the rear crossmember that holds the spare tire carrier is looose so I will have to knock out some rivets and replace with bolts tomrrtow.
Last week I took the cab down to have sandblasted inside and out and then epoxy primed.
http://s783.photobucket.com/albums/...=view&current=cabtobesandblasted.jpg
This morning they called and said to come and get it, it was done. I was was really happy there wasn't much rot in it.
http://s783.photobucket.com/albums/...tion=view&current=primedcab82312.jpg
Here's the build so far:
http://s783.photobucket.com/albums/...pick%20up%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Looking gooood. Now the fun begins...putting it back together smile
I finished installing heat reflective barrier in the cab,still waiting for my new gas tank to arrive.
More pix on Flickr.
Jockbolter, nice install on the heat shield. It will make a big difference in sound also.
Wayne
1989 Silverado
Thanks,not sure if it'll ever be totally rattle free(it is an old truck after all) but even now there's a huge improvment in the noise levels and fewer rattles!
More pix on Flickr.
^ I'm gonna have to try that once I get the new sheet metal in. As is conversation is suspended until I get to cruising speed in third.
I finished the wood bed for now.
bed
It's almost ready to go back to work on the farm
back side
Once the PT wood dries it will be stained black.
Wayne
1989 Silverado
OOOOOOHHHHHH nice. I like the looks of that truck. Beep Beep. I am still removing paint and bondo and taking care of the body work. Thought I was almost done, but found that someone hid some dents with a bucket of mud.
1948 Chevy 2-Ton
Wayne, I just have to comment on your truck. Absolutely a nice job. awesome looking.
Thanks for the compliments. I still have to finish the interior. I'm also having a sticky float issue that needs corrected.
Wayne
1989 Silverado
The bed looks nice.
bed
back side
It's too purdy to work on a farm.
~Jim
Ditto on that Alvin,seems like just a short while back it was just a pile 'o' parts! thumbs_up
More pix on Flickr.
bed
back side
Great job Wayne! I agree, too special to work on a farm.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Wayne, beautiful truck! thumbs_up
This is what I have gotten done this week:
bought sandblaster (after researching and talking to several guys at work who have some and use them regularly)
sandblaster ready to shoot the cab roof
removed hoses and saran-wrapped the engine
see pic
set up my curtains and closed in the booth
attaching hangers to sheeting
first curtain up
sandblasted 1/4 of the top of the cab
starting out
salvaged sand and stored for later screening and reuse
brooming sand from hood
collecting sand from tarps
visible progress is being made and I'm happy !! grin
I just bought that exact sand blaster. Glad you are happy with it.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Got the gumption up to try welding for the first time. Needless to say, it wasn't pretty, but the weld has held so far. In an experiment to see if I can get the frame off of the axle with the way the PO had ran the leaf springs, I've decided to try welding two 1" x 1" square tubes together to place between the leaf and the axle. If it doesn't work, at least I got to try welding out smile
If all goes well this weekend, I may actually get the air shocks in place and the leaves put back into place. If I get frustrated, there's always something that needs de-rusting and painting!
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I ordered vent window seal kits and lower door window seals for my '59 doors.
I'm aiming to do some final body work on the doors this 3-day weekend...
Maybe set the new vent window glasses in my newly painted frames. smile
A little progress always feels good!
I picked it up from the shop. had an alignment, new front tires new right tie rod, and right ball joint. also at another shop i had an oil change, clutch adjustment and worked on the cruise control, it still does not work right, it will shut off with the brake but not with the clutch.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Got the frame cleaned up, and por-15 is on.
http://s960.photobucket.com/albums/ae90/scrambler45/
Gutted the original 37 coil to get it ready to slip over a 12 volt coil and cut off the conduit from the original ignition switch,hated to do it but a couple of the original parts will be going back on and will fill up a hole in the firewall. I was hoping I could use the original ignition switch since it will be going back to the foot stomp starter but I wired the truck for a ignition switch with a accessory post.
Removed torque tube out of my '51 project. Took a bit longer than planned but got it done alone so that was rewarding. Use my engine lift to lift frame while a floor jack supported the axle. next step getting up to speed on lining up my '73 camaro rear axle. Picking up a '55 235 on wednesday. this is progress.
1951 Chevy 3100
While waiting for my new gas tank to arrive(another story) :mad:
I decided to try my hand at some basic carpentry.
I formed a wooden framework over the gas tank and sheeted it with 1/2" and 1/4" ply,sunk my rear speakers in,I also fitted my front speakers in where the original was.
The head unit now resides in the glove box,I hate to see sheet metal cut up for hi-fi installations....
Note: NO Chevrolet was harmed in the making of this thread...... wink
More pix on Flickr.
http://s783.photobucket.com/albums/...action=view&current=firewall9412.jpg
After 54 years of use the firewall had quite a few extra holes in it. So yesterday here was our solution:
http://s783.photobucket.com/albums/...on=view&current=diamondplate9412.jpg
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Well that definitely works. Looks good with the rest of bling under the hood.
1948 Chevy 2-Ton
