Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (SandraD, baldeagle, farmallb, Peggy M), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#8761 06/16/2004 1:28 AM
Junior Member
Junior Member
I have a 1958 Chevy Apache 1/2 ton. My dilema is wether to keep it stock or custom it(newer frame and all). I just don't know what to do.I am finacially strapped like everybody else so keeping that in mind, I do have friends that can help me if I could just make up my mind.Any advice would help. The truck seems to be a real plain jane, not even a turn signal arm or a heater.235 6 cylinder, three on the tree. Please give advice.Please....
1958 Apache Frank
#8762 06/16/2004 1:50 AM
Red dot, center of chest ...
That's really a decision that you can make several times. You could start out by repairing what needs to be repaired so that you can drive the truck and enjoy it. As time goes by, you may decide you want to make some changes. I would take some time, go to the swap meets and car shows and look at what others have done. Decide what you like and what you don't like. All the while, you can be enjoying your truck. This also gives you time to find out what things cost and decide what you want to do.
You can also do a lot using parts from the junk yard and by doing a lot of the work yourself. And if you "screw" something up, you can always fix it later.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#8763 06/16/2004 2:48 AM
Building a truck is all just a matter of taste, your taste. Do it the way you like it. If you ask that question here, you will get a hundred different replies. If the truck has no collector or sedimental value, do what you like, most of us won't care and we'll support you. I personally would make it road worthy and drive it. Get a feel for what you like and dislike about the truck. Then start collecting parts and donor vehicles. It's all about having fun,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#8764 06/16/2004 3:17 AM
Pal Offline
For the most part, I agree. Just no Furd parts! grin
35 + years of rollin' steel!
#8765 06/16/2004 3:27 AM
Just do it the way you want,,,keep it chevy,,,Fred
Redryder pix
My Hotrod
#8766 06/16/2004 4:55 AM
Junior Member
Junior Member
Just want to say thanks to everybodys input. I think that the smartest way to go is to road worthy it and then see where the truck goes.Thanks again.
Frank
1958 Apache Frank
