| | | Forums66 Topics128,007 Posts1,055,275 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 2 Junior Member | | Junior Member Joined: Jun 2004 Posts: 2 | I have a 1958 Chevy Apache 1/2 ton. My dilema is wether to keep it stock or custom it(newer frame and all). I just don't know what to do.I am finacially strapped like everybody else so keeping that in mind, I do have friends that can help me if I could just make up my mind.Any advice would help. The truck seems to be a real plain jane, not even a turn signal arm or a heater.235 6 cylinder, three on the tree. Please give advice.Please....
1958 Apache Frank
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | That's really a decision that you can make several times. You could start out by repairing what needs to be repaired so that you can drive the truck and enjoy it. As time goes by, you may decide you want to make some changes. I would take some time, go to the swap meets and car shows and look at what others have done. Decide what you like and what you don't like. All the while, you can be enjoying your truck. This also gives you time to find out what things cost and decide what you want to do.
You can also do a lot using parts from the junk yard and by doing a lot of the work yourself. And if you "screw" something up, you can always fix it later. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Building a truck is all just a matter of taste, your taste. Do it the way you like it. If you ask that question here, you will get a hundred different replies. If the truck has no collector or sedimental value, do what you like, most of us won't care and we'll support you. I personally would make it road worthy and drive it. Get a feel for what you like and dislike about the truck. Then start collecting parts and donor vehicles. It's all about having fun, Scott | | | | | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | For the most part, I agree. Just no Furd parts!
35 + years of rollin' steel!
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Just do it the way you want,,,keep it chevy,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2004 Posts: 2 Junior Member | | Junior Member Joined: Jun 2004 Posts: 2 | Just want to say thanks to everybodys input. I think that the smartest way to go is to road worthy it and then see where the truck goes.Thanks again. Frank
1958 Apache Frank
