Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (TUTS 59, GMCJammer51), 267 guests, and 1 robot.
Topics128,290
Posts1,058,566
Members48,492
Page 71 of 177 1 2 … 69 70 71 72 73 … 176 177
My package arrived containing my new vent window glasses, door wipes and division bar felt for my '59. YAY!!
On another note while at the location of the '58 donor truck yesterday, I wirebrushed the dirt away to reveal the head casting number on the 261 engine. The head is a 261 with matching blue paint under all that dirt and grime. I really want to tear this puppy down. I'd be very happy to use that engine in my '59.
Got the old girl outta the paint shop thumbs_up after a close encounter with a engine stand cry and a overfull gas tank that runneth over... :mad:
GMC: Get More Cash...
1958 GMC
My Webshots photos
Finally got the windshield out. Everything was frozen the frame is shot so I had to cut it,Saved the crank mechanism, now if I can free up the hinges I can get them out.
I see a lot of people set in a fixed windshield is this because the crank outs leak and whistle?
1937 Chevy 1/2 ton panel
Don't know about that but as a kid I was always fascinated by the crank out windows. My grandad was a district manager with General Foods and they gave him a car. I was pretty young but I remember the crank and he could hardly keep my hands off his. I would be tempted to do whatever it took to keep the crank.
~Jim
WELL PEOPLE I FINALLY GOT SOME PAINT ON MY 1946 CHEVY PICKUP IT COULD HAVE BEEN BETTER BUT ITS A WHOLE LOT BETTER THEN IT WAS PLEASE FEEL FREE TO CHECK IT OUT http://coreys46chevytruck.shutterfly.com/
HEY MAN NICE TRUCK WE NEED TO EMAIL EACH OTHER IVE GOT A 46 AND MAYBE WE CAN SHARE SOME PICS AND IDEAS [email protected]
Built a low stake side out of white pine. Storms rolled in so I only got it mocked up and loosely bolted together. Gonna finish up the sanding and varnishing this week.
http://rustyfiftyone.com/2012/08/04/a-bit-of-wood-work-on-a-warm-summers-eve/
On the bright side the visor looks great!
Pun intended? ...visor, bright side... haha. wink
Thanks man! cool
Thanks man! cool
Eric... I was going to ask about your running issues but I saw your comment at the bottom of your blog,good luck,I hope you get it sorted soon.
No point in having a cool looking truck if you can't go anywhere in it!
More pix on Flickr.
Rebuilt the carb, got the heat riser out of the old manifold and into the new. Now thinking that maybe I should go with the Offenhauser dual intake,not quite sure what that will take to accomplish.
carmental
i finally got my 3" drop axle back under the front of my truck and back down on all 4 wheels, now to hook up the tie rod and drag link today, my truck is really starting to come together
Pics? Where are the pics? pix
~Jim
Finally got the truck out of Austin Speed Shop, where they redid the suspension and brakes. Failed inspection for emer brake, turn signals, and a couple of other things, so will retry tomorrow, at B&B Automotive on Lamar. Took the day just acquainting myself with this wonderful pile of metal! My wife even got on the creeper and I showed her what an old truck looked like from the bottom.
One thing I noticed is it tends to stall when I turn a corner, and idle down. I wonder if is just idle speed, carb float level, or maybe vapor lock from heating up on a 100+ day.
Ed Burgess
"It's all good!"
Sounds good ED. Please ask the engine question in the engine forum.
Thanks.
I finally got the 30 back on the road. I am in the process of finishing up the 54. I still need to install the glass.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
You ain't kidding man. The wait is killin' me.
Was gonna rebuild the current fuel pump but I figured this was as good a time as any to upgrade to the dual action pump with vac assist.
Changed the valve cover gasket as it was old and hard and had started leaking over the manifold.
Thanks for the redirect, Cletis! Can't wait to tear into this machine!
Ed Burgess
"It's all good!"
I had quite a productive day,well at least by MY standards!
Stripped out the left front suspension and fixed the air leak,set the alignment and camber,and finally stripped and painted the right hand valve cover to match the left one that I did about 2 years ago.... blush
BTW removing powder coat is a real PITA!
More pix on Flickr.
Finally made up my last brake line for my 1950 Chev PU. Decided to upgrade the master cylinder and of course all new brake shoes and wheel cylinders all around. Had to drill some new holes to position hold down clamps for the new lines and the next step is to bleed the system and carry on with some body work which I started last fall. Lots of distractions but I'm determined to forge on.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Big Chevy 3600 wanted to see a picture of where I mounted the tach in the panel. I used the hole for the e-brake bracket since I'm using something different.
Here's the picture,Jim.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/BowtieBrakePedal002.jpg
...and my new brake pedal pad. Thanks to a fellow bolter for doing it for me.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/BowtieBrakePedal001.jpg
I like it, hope you did not get to hot up under that dash. Good thing the seat is not in yet to give you a little extra room. thumbs_up
Drive with Pride. mike j
family pic
Thanks for the pic Alvin. That is one cool brake pedal.
~Jim
That is a tiny tach. I wouldn't think an old man could see it from the drivers seat.
Cletis, I didn't think you had a funnybone.lol
~Jim
Didn't do it myself but the cab is back from the painter's.
http://img.photobucket.com/albums/v518/Blacktailer/IMG_5323.jpg
http://img.photobucket.com/albums/v518/Blacktailer/IMG_5324.jpg
Should get the fenders on next week and then I can finally start the final assembly.
Today carrier bearing and driveshaft installed, sanded, painted gear/brake shift cover. Installed door regulator.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Big Bolt Forum Co-moderator
Wow, that looks good. What is that textured paint on the floor? Is that a sound deadener?
1948 Chevy 2-Ton
I got the radiator and fan shroud pulled out of the '61.
more pics of radiator: Pic 1 and Pic 2
I finished wiring my 454-30 (except for headlights), Started building new sideboards/gates for the dump flatbed, purchased new Gas and Temp Gauges, also purchased spare 11" clutch for my 48 GMC pickup w/270 engine.
Made arrangements to go get the GMC 454-30 parts donor truck I bought, on Sat.
Drank lots of coffee...
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Yes it is heavily textured and sprayed on the floor inside and out. Should keep rust to a min and help with sound.
That's looking great,time to start fitting all the goodies!
Shouldn't that be..."DRANK LOTS OF COFFEE!" grin
More pix on Flickr.
1 Offline
I found a Center Console out of a 1998 Tahoe that will work with the Bucket seats I got for the 51. Getting ready for some interior paint and new carpet.
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
laalaa laalaa laalaa grin
1958 GMC
My Webshots photos
Got the front trim pieces back from the media blasters. They look BEAUTIFUL!! Never seen such a sight. Purdy medium grey with shiny speckles. Rough, sand paper feel. Oooh! No more rust. No more paint. Amazing! Me thinks I'm a fan of media blasting. grin
Put two coats of primer on before storing them out of the weather 'til the rest is ready to be primed and painted. I'm making progress on the ol' gal. smile
Me too!!!!!
~Jim
Received my passenger side latch from Robert(mobileortho) this morning,got home from work,cleaned and greased the latch,installed it and it works like a charm!
Thank you once again Robert! thumbs_up
More pix on Flickr.
Finished wiring in the new 12 volt alternator & test ran! Worked great!
Went to HF this morning and got an air sander, discs, paint gun set, etc...
Then we got the temporary shelter up for the work on the truck. It's amazing what you can do with two 16' pine poles, a used dog trolley cable, 7 canopy poles, and a 30' x 40' tarp. It's not fancy, but it will work. grin Hopefully, it stays in one piece. LOL
Pic 1
Pic 2
New shoes, wheel cylinder and axle seal on the right rear. Round 2 on the left side tomarrow. Then to throw new wheel cylinders up front, new master cylinder, reinstall the gas tank and hopefully fire her up.
1953 1 ton panel
Got the rebuild kit installed in the Edelbrock 1405 carb. Going to drain to old gas out of the tank tomorrow and put in some fresh gas, put in new points, condenser and rotor button, check the plugs, install the freshly charged battery, put the carb back on and hopefully get it fired up and running. It has been sitting for over a year now and I have a hankering to get him back on the road.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
