0 members (), 129 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
Looking to find the best fit tilt floor shift steering column for a 1953 3100 truck - not aftermarket? Any ideas?
Thxs
Try a mid 80's Jeep Cherokee
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
If you are installing power steering those little steering wheels will be fine. If not, go for something with a bigger wheel or modify to use an original size steering wheel. As for a source, you need to look in the older vans for the bigger wheel.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
1 Offline
I installed a column from a 1981 Chevy Van, It fit awesome ! I didnt even have to adjust the shift linkage.
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
1 Offline
Oops... I didnt read your question all the way through, mine is a column shift.
But it worked out sweet thumbs_up Good luck on yours !
i used a 75 chevy van column...i sent it off to a guy in Missouri who went through it...ended up replacing a bearing and redoing something in the electrics...he also shortened the tube and shaft to my specs and ground and filled the shifter hole.all said and done about $140.00 plus shipping..i'm happy with it...dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I know you said " no aftermarket ", but you might want to check out Summit Racing - $ 235.00 for a new column is pretty good !
1940 Chevy KC 1/2-Ton
I have one from a 1988 C1500 floor shift ,I'd take $50 + shipping for it
I don't knwo about the Cherokee but I had a 86 Grand Wagoneer and a large percentage of the parts AMC bought from other manufacturers. The steering column was Chevy, the motor was Chrysler via Ford. I always reminded me of that Johnny Cash song.
~Jim
sps Offline
I used one out of a 94 Suberban. I used my original steering box. Bobed the box and the colume. Was some work but turned out nice. Steers the same.
I've seen them at most hardware/home improvement stores. I even have the Harbor Freight kit mentioned. I've never been able to find the large clutch head driver like what is used on your fenders. (sorry, the size escapes me)
Chris
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Any pics of install tilt columns in ad trucks?
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
Not in a AD but i used a column out of a 1987 monte carlo and it works nice. no problem with the small wheel on manual steering, only would be helpfull in a small parking space, i just park out a little bit and walk.
although in smaller old trucks i've found that a tilt is not really needed unless you are a "big, fluffy" kind of guy.in a car yes.
be carefull of Inexpensive or "cheap" aftermarket columns, some are for show and arent very good on the road. you get what you pay for.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
Herb, I think someone already mentioned a chevy van. Not sure about the year but maybe early 80's that is the right length.
There have been mucho posts on this topic. I believe years ranged from the mid 70's into the 80's. I would check the archives here to be sure.
~Jim
