3 members (BC59, dt235sd, Wooley),
124
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 14 New Guy | | New Guy Joined: Oct 2011 Posts: 14 | I am looking to see if anyone has a link or a picture of a stovebolt with an 88-98 sportside bed? Ive found two pictures and they are the same angle from the front of the passenger side of truck where you cant really see the bed much. I am looking for a side angle or back angle.
RealMenDriveTrucks...
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | you can of course do with your street rod whatever you like. that being said, the lines of the 90 bed would not complement the cab body at all. if you need a bed, there are new reproduction units availible, or build/buy a flatbed to put on it until you can get one. good quality used beds are getting hard to come by. just my opinion.
daren | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I've seen a few over the years. I agree with the previous posters in that the "90's look just doesn't blend well with the 50's cab and front end. JMO | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | To each his own... I saw an AD truck with an 88-98 Fleetside bed that had been narrowed then the AD fenders were grafted on. Great workmanship. Actually looked better than one might think.
Professional Novice
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I've seen several done. While some look better than others, in my opinion none ever look good. You can do a google image search and probably turn up hundreds, with the right key words. | | | | | Joined: Jun 2012 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 64 | If you like the look go for it. You will probably get a lot of people whispering though. Critics are everywhere but who cares what they think!!! I would go with the wooden flat bed look as said previously until yoiu can buy the correct bed. Pine is cheap and looks good once urethaned natural. But that's my opinion and no one cares about that either!!! LOL | | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | Since you want a goofy looking truck, you might as well do this too. | | | | | Joined: Oct 2011 Posts: 14 New Guy | | New Guy Joined: Oct 2011 Posts: 14 | I was looking to "shave" the steps off and blend in the factory 50 running board, leaving the steps on would stick out past the cab and WOULD look stupid! I think the narrowed bed would probly blend in well with steps shaved off, that is the main reason i asked if anybody has a pic or knows a link... I have Googled and Yahooed several weeks and only found 2 pics that barely show the passenger corner of the bed from the front of truck. I did see the one where they narrowed a fleetside bed and put fenders on the sides and yes that did look good and blended well, that would lead me to believe the sportside would look good too. I cant be the only person that has ever thought about this, someone has to have already done it and have pics.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Do what you want and don't worry about what others think
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2011 Posts: 14 New Guy | | New Guy Joined: Oct 2011 Posts: 14 | well if i decide to do this and get around to doing it i will definitely post lots of pics.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | That's the spirit!  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....GIT R DONE. Go for it. Variety is a good thing. I've seen a couple 40's Ferd pickups with Ranger flared bed sides and I've seen a Chevy pickup or two with a flared S10 pickup bed on them and tastefully done I couldn't say they didn't look good. Sorry I didn't get pics.
| | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | This is just wrong. It goes against nature. An abomination... Why would someone do that to an old truck? Why? To each his own.
Professional Novice
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | If you do it, take the time to re-arch the wheel well opening. The stepside bed is kind of squared off while the AD front fender opening is rounded.
My $0.02
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Another option is to get some sheet metal rolled to the same contour as the door and have it extend from the bed side roll down to the bottom, with a relief cut around the AD fender. Saw something like it in one of the magazines. Looked good when it was done.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Oct 2011 Posts: 14 New Guy | | New Guy Joined: Oct 2011 Posts: 14 | Definitely some good ideas.
