2 members (Red75bronco, wvstovebolt), 99 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
I have a few questions on my gauges and reducing the voltage to 6v. 1946 GMC
Do I need to reduce the voltage on the wire coming from the starter going to my my amp gauge? I don't think so, mainly because that is the primary power feed for everything else. But then will my amp gauge read correct?
I have a power wire coming off the ignition switch that goes to my temp gauge that pig tails up to my gas gauge. I was thinking I would reduce the wire coming into my temp gauge to 6v and then the loop that goes up to my gas gauge will be 6v. Anyone see a problem with that.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Riding in the Passing Lane
The amp gauge will be OK unless you use a high powered alternator. The best thing for the gauges is the Runtz resister. It needs one for each electrical gauge. I thought the temp gauge was a capilary tube. The Runtz is available at most specialty stores.
1972 Chevy c10 Cheyenne Super
Jason,
Take a look at this Tech Tip. It should help you with your questions.
http://www.stovebolt.com/techtips/12_volt_conversion.html
Harold
Harold
GMC used electric temp gauges through some years. They will not work with the Runtz resistor. I havent tried it without the resistor yet and the 6 volt sending units are nearly impossible to find to accurately match the GMC gauges.
That just leaves one needed for the gas gauge.
Amps are amps regardless of voltage. It could be 1 volt or 100 and it wouldn't affect the amperage.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Why will the GMC temperature gauge not work with a runtz resistor? What's the diff in principle between the way the fuel gauge and temperature gauge works? Thanks for the info.
David
Gas Pumper
Gas Pumper
What most people don't know is that a 6 volt Zener Diode is all that is needed on the gauges. One for each. Cost is about .89 cents (or less). Face the Silver Stripe away from the gauge and you are good to go. Do not do this for anything but the gauges.
That is what this is:
http://www.ebay.com/itm/Dash-Gauge-Voltage-Reducer-12-6-Volt-Runtz-Diode-to-resistor-b-/291161623894?hash=item43ca95cd56:g:wM4AAOSwfcVUEzHN&vxp=mtr
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
