1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 13 New Guy | | New Guy Joined: Feb 2012 Posts: 13 | After reviewing info on the forums i gave the wood bed 4 coats of linseed oil and three coats of stain. Will let it weather and put on finished coats later. Thanks for the info. You guys are appreciated. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Wow! That is turning out GREAT!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yes it is. Keep us posted as you go along. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Feb 2012 Posts: 13 New Guy | | New Guy Joined: Feb 2012 Posts: 13 | Not sure what wood, it was in the truck when I bought it in February, possibly red oak if there is such a thing. Was pretty red when I coated with linseed oil, so I stained it with red mahogony. In two or 3 months I will give it several coats with polyurathane that has pecan stain mixed right in it. I know what it will look like because I just refinished my farm house kitchen table and a dresser this winter with the same process. | | | | | Joined: Feb 2012 Posts: 13 New Guy | | New Guy Joined: Feb 2012 Posts: 13 | Had to go darker because the wood was stained with motor oil, grease and tar from the junk the previous owner threw in it. | | | | | Joined: Feb 2012 Posts: 13 New Guy | | New Guy Joined: Feb 2012 Posts: 13 | Not bad considering the deck cleaner was $ 3.00 and the linseed oil cost 3 bucks and the stain was $4.88. Used $20 dollars worth of sandpaper for a total of $30.88 | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Factory would have been pine, but could easily have been oak that was replaced later on. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | The wood is oak. Looks great. | | |
