2 members (Hotrod Lincoln, Southerntruck), 109 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#843163 04/11/2012 11:02 PM
After reviewing info on the forums i gave the wood bed 4 coats of linseed oil and three coats of stain. Will let it weather and put on finished coats later. Thanks for the info. You guys are appreciated.
My 1966 Chevy C-20 Custom Camper: http://photobucket.com/wowsmithhere
Wow! That is turning out GREAT!
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Yes it is. Keep us posted as you go along.
What kind of wood?
Not sure what wood, it was in the truck when I bought it in February, possibly red oak if there is such a thing. Was pretty red when I coated with linseed oil, so I stained it with red mahogony. In two or 3 months I will give it several coats with polyurathane that has pecan stain mixed right in it. I know what it will look like because I just refinished my farm house kitchen table and a dresser this winter with the same process.
Had to go darker because the wood was stained with motor oil, grease and tar from the junk the previous owner threw in it.
Not bad considering the deck cleaner was $ 3.00 and the linseed oil cost 3 bucks and the stain was $4.88. Used $20 dollars worth of sandpaper for a total of $30.88
Factory would have been pine, but could easily have been oak that was replaced later on.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
7
7 Offline
The wood is oak. Looks great.
