5 members (DadsFirstPickup, Ponchogl, ronsway, Jman, tclederman), 119 guests, and 1 robot.
Topics128,102
Posts1,056,531
Members48,448
#819665 01/25/2012 7:05 PM
Any suggestions to help me paint my engine while it's in the truck? Sittin' on the garage floor - no lift, no stands. '54 235 4-speed
I ordered rattle can and brush-on dark grey engine paint from The Filling Station. I'll prime and wet sand the valve cover and pushrod cover. Any reason to prime the block? If so, with what? I'll brush the block to avoid over spray.
I Gunked it this morning. I'll clean it a couple of more times. What do you suggest to clean it?
Gonna try to paint it without removing the radiator unless I find that I need to when I replace the water pump. Or do you think that I should just go ahead and take it out?
Is it possible to paint the bell housing / clutch housing? Looks kinda tight.
I'll paint the valve cover, push rod cover, water pump (replacing), filler necks, and possibly the timing cover off of the engine. Remove wires, plugs, gen, hoses, fuel & vac lines, and road draft tube, to get out of the way.
I'm tempted to drop the oil pan and paint off the truck, but I'm afraid of what I'll find.
- Lonnie
My '54 3104
I would not pull the motor to paint, just mask off all other areas etc. Would paint the pan in place, timing cover as well. You could check with a paint store for a cleaner or something like lacquer thinner should work.
1946 1/2-Ton Chevy
i found it very tedious and less satisfying leaving the engine in to paint it. what i found to be easier and somewhat satisfying is to paint everything but the block and the head but clean the block and head up the best you can. removing all the bolt on stuff and painting then bolting it back to shows that maintenance is being performed and paint is a form of maintenance. the best way is to have the engine out to be totally satisfied with the results.
I would pressure wash it.
Thanks for your input and experiences -
Pulling the engine is not an option.
"Boltr#43" - I'll paint the pan and timing cover in place. (Originally thought the timing cover was an easy removal)
"51 aston" - Yes, this is gonna be a tedius job! I'll remove everything that I can before painting the block.
"Builder" - I agree about pressure washing, but my pressure washer died last year. I Gunked it yesterday. Used a $7 siphon engine cleaner from HF to cover everything with Gunk. Did a good job of getting it in crevaces and tight places. But "blasts away dirt, grease, and grime" is an exaggeration!. Standard water hose pressure cleaned it up pretty well. I'll Gunk it again and maybe borrow a pressure washer. Spot clean with acetone as needed. Luckily, the engine and frame were fairly clean to start with.
The "while-you're-at-it" syndrome is starting to kick in. I may scuff sand and paint the inner fenders, too.
- Lonnie
My '54 3104
I've had good luck using Simple Green and a couple stiff scrub brushes. Wet things down, then spray with the Simple Green and start scrubbing. Have a bucket with water and Simple Green mixed to clean the brushes. Rinse and repeat a few times. If you have air it works good to blow it dry, then you can see if you missed anything. Once I get things clean and ready to paint I take a clean rag and soak it with lacquer thinner and wipe it good. Once it's dry paint away. Good prep work pays off with a good finish and one that won't flake off.
Don
I finished painting my engine and engine bay with the engine in the truck. Not a speedy task. Seemed like I would spend a couple of hours masking, then paint for a few minutes. I removed most of the parts to clean and paint off of the engine. Didn't remove the carb or lines because I didn't want to create leaks. Thanks to DavidF for the aluminium foil masking tip in another thread.
I used almost three rattle cans and a quarter of a pint of brush-on of Filling Station engine paint. I found some areas on the engine that I missed. Can't touch them up now - already getting oil on them from oozing valve cover etc.
I thought that I had the job planned out pretty well, but I ended up masking and painting multiple times in the same areas. Suggest painting the frame areas first, then the engine, and the inner fenders last. (I painted the engine first.)
Used Calyx on the rusty exhaust manifold. Looks great and was simple to use. Also used it on accelerator, brake, and clutch springs.
Here are the paints that I used:
ITEM / / BRAND / / PART # / / DESCRIPTION / / SHEEN / COLOR (Notes)
Engine / / Filling Station / / FS-359 & FS-119P / / Engine Enamel / / Dark Gray
Generator / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Starter / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Generator Brackets / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Starter Rods / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Heater Hose Bracket / / Rustoleum / / 7798830 / / Protective Enamel / / Semi Gloss Black
Frame / / Rustoleum / / 7777830 & 7777502 / / Protective Enamel / / Satin Black
Steering Box / / Dupli-Color / / DE1651 / / Engine Enamel / / Cast Coat Iron
Inner Fenders / / Rustoleum / / 7777830 / / Protective Enamel / / Satin Black
Headlight Buckets / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Headlight Inner Bucket / / a coat of Rustolium aluminum and a mist of Rustoleum Galvanized
Fan / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Air Cleaner / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Coil Bracket / / Rustoleum / / 257884 / / Automotive Enamel / / Gloss Clear
Coil / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Radiator / / Rustoleum / / 7798830 / / Protective Enamel / / Semi Gloss Black (Similar to Auto Semi, I had more Protect available)
Steering Column / / Dupli-Color / / DE1634 / / Engine Enamel / / GM/CHRY Low Gloss Black Flat, slight grey tint - similar to column inside cab)
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
I posted the results of painting the frame and inner fenders in another thread.
Thanks for your help in pointing me in the right direction.
- Lonnie
My '54 3104
Bravo! looks awesome.
Great looking job Lonnie, thanks for sharing it with everyone.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Lonnie, you are an inspiration.
Nice job, and thanks for the information and instructions.
I painted my motor out of the truck and it does not hold a candle to yours Lonnie !
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
is that the color paint from filling station
i just got my can from them and i started to
paint my engine my can of gray looks almost
black it seems to dark
Keith -
Yes - the paint on my engine is from The Filling Station. I felt the same way when I sprayed the first item. It seemed way too dark ... almost a charcoal grey. I'm used to it now and it doesn't seem so dark. The contrast between the grey engine and the black inner fenders may make the grey paint appear lighter than when viewed by itself out of the engine bay. The photos were shot with flash, plus I PhotoShopped them a little, so they may appear a little lighter grey than they actually are.
I'm happy with the color of my engine, but I could have been equally happy with a little lighter shade of grey.
Tim Lederman's recent reply showed the "controversy" over the right shade of paint for Stovebolt truck engines.
- Lonnie
My '54 3104
After reading the post by Tim about the fervent followers of the faithful paint I realize I am a godless pagan who will no doubt be responsible for the west coast tsunami when it finally arrives due to my use of Orange and Black engine scheme :mad: eeeek
Give me ambiguity
or give me something else
Ignore the fervent followers. Especially when they say they know theirs in the one and true way.
In fact, orange and black do look like pagan colors? Some of my best friends are pagan (some have interesting-colored engines).
Hey Tim, can't we be both fervent followers AND pagan?
Great job on the engine, Lonnie!!
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Excellent Lonnie. Thanks so much for sharing.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Wow,looks really nice !!!
Tim
1951 3100 Chevrolet
nice!!! great job
