3 members (klhansen, ronsway, 1 invisible), 165 guests, and 1 robot.
Topics128,106
Posts1,056,213
Members48,436
#840831 04/03/2012 7:32 AM
I WOULD LIKE TO KNOW IF BOTH RIGHT AND LEFT LOWER REAR DOOR EDGE GLASS GUIDE ARE THE SAME SIZE. THAT THE WINDOW GLASS RUN CHANNEL FIT IN. MY RIGHT SIDE FIT SNUG TO THE FRAME BUT THE LEFT SIDE IS ABOUT THREE EIGHT AWAT FROM THE FRAME IS ONE TALLER THEN THE OTHE
PEPSI
...I think your talking about the AD years. If so I believe the earlier years are wider and the later years, like my 52 are narrower. Both are the same size but there is a "left" and a "right". New ones are available from vendors for about 15-20 dollars.
EDIT: sure like your "handle". I'm a Pepsi man myself but like it with a couple hot dogs! Welcome to the Stovebolt.
Pepsi,you're a little vague about which year of truck but if it's an AD like Alvin says the rear glass guides are handed left and right.
The bottom mounting brackets are offset to fit the shape of the door.
Pre-51 will be different from '51 and later due to the vent glass and frameless drop glasses.
Sounds like you may have one of each.
More pix on Flickr.
Moderated by  ndkid275, Phak1
