7 members (Charles in CA, LAROKE, Wally / Montana, Cletus1950, 78buckshot, TrknGMC, UtahYork),
137
Mod | | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 6 New Guy | | New Guy Joined: Mar 2006 Posts: 6 | I WOULD LIKE TO KNOW IF BOTH RIGHT AND LEFT LOWER REAR DOOR EDGE GLASS GUIDE ARE THE SAME SIZE. THAT THE WINDOW GLASS RUN CHANNEL FIT IN. MY RIGHT SIDE FIT SNUG TO THE FRAME BUT THE LEFT SIDE IS ABOUT THREE EIGHT AWAT FROM THE FRAME IS ONE TALLER THEN THE OTHE PEPSI | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I think your talking about the AD years. If so I believe the earlier years are wider and the later years, like my 52 are narrower. Both are the same size but there is a "left" and a "right". New ones are available from vendors for about 15-20 dollars.
EDIT: sure like your "handle". I'm a Pepsi man myself but like it with a couple hot dogs! Welcome to the Stovebolt.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Pepsi,you're a little vague about which year of truck but if it's an AD like Alvin says the rear glass guides are handed left and right.
The bottom mounting brackets are offset to fit the shape of the door. Pre-51 will be different from '51 and later due to the vent glass and frameless drop glasses.
Sounds like you may have one of each.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
