| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82770 09/09/2007 4:35 AM | Joined: Aug 2007 Posts: 9 Junior Member | | Junior Member Joined: Aug 2007 Posts: 9 | Hey everyone! I made a post earlier about putting a 261 in my 1950 3/4 ton chevy PU which I appreciate all the fast and informative replies. Here is my next question. My intentions for this truck is to have my son help me build this over the next few years and let him have it as a 16th B-Day gift. We will do all the work ourselves and stick with the original look and feel. Should I update to the 261 or should I make it true blue stock and stick with going back to the 216 in which it would be worth more down the road? And does anyone have a easy build 216 available as mine has a 1/4 inch crack running down all cylinders. I am open for any and all opinions. Just looking for that inspirational one that will help set our path! | | |
#82771 09/09/2007 3:53 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Since you have to change engines anyhow, go with the 261 I'm sure you will be glad you did. A little more power makes any vehicle easier to drive, and more fun. | | |
#82772 09/09/2007 5:16 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Unless you are going to do an absolutely "bone stock" restoration, I'd bet that the value of the truck would be more with the 261 engine. If you are really worried about the diminished future value, just keep an eye out for a used 216 engine (with correct casting numbers), so you have it available if you ever sell the "restored" truck. | | |
#82773 09/09/2007 7:28 PM | Joined: Aug 2007 Posts: 9 Junior Member | | Junior Member Joined: Aug 2007 Posts: 9 | Thanks for the input everyone! You have convinced me of the 261. I just needed the extra nudge. | | |
#82774 09/10/2007 9:02 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Bowie: There is a discussion going on here I believe I saw it on the "engine/driveline" section you should read. A stovebolter has a 216 engine that seems to be in good shape and willing to sell. You might check it out if you're determined on a 216. Personally I would prefer an upgrade and away from those babit bearings.
~Jim
#82775 09/12/2007 12:34 PM | Joined: Nov 2005 Posts: 8 Apprentice | | Apprentice Joined: Nov 2005 Posts: 8 | bowie, I am looking on upgrading my 216, as soon as i can find a 238 or 261 engine to put in. My 216 need some work nothing major i believe just needs some new pushrods. if you are dead set on going with the 216 i will let you know as soon as mine comes out.
Aaron L. Springer
#82776 09/13/2007 2:56 AM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | if your going to update the 6 you might as well update it all the way and install a 292 from the 1970s | | |
#82777 09/13/2007 5:08 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | he'll love the 261 & love you for it
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#82778 09/13/2007 7:35 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | You could use a 216 valve cover on a 261 to make it "look" stock. To make it a driver for todays roads and speeds, you will want a T-5 tranny or an O.D. and definately radial tires. A brake upgrade will be most important. | | |
#82779 09/14/2007 12:09 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have a usable 216 out of a 40 car that I'll GIVE you if you need it. I'll throw the rear axle assembly in with it. All you have to do is come get it. Unless you're going to work the truck you'll see little advantage with the 261.
#82780 09/14/2007 12:38 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I had all sorts of plans for mine before I ran the numbers and realized it still had the original drivetrain in it. That changed plans, I thought it was cool and plan on keeping it 90% stock. I wouldnt go that route unless your a purist. Think about it, if you want to give the truck to your son are you gonna add those safety items like seatbelts or turn signals that didnt come with the truck originally? I really dont think it is that big of a deal or will make any difference to the future value. Use the 261. Keep it stock-ish if your really concerned. Im doing upgrades on mine like 'painting' the drivetrain and frame. Go figure, if somebody wants to get all anal about me painting it, tough cr@p. I did a good job that will last till Im dead and gone. What about upgrading the brake system? Another good thing if your future 16 year old will be driving it. Think about all that before you decide what route to go. And remember WE WANT PICTURES!  By the way, Welcome to the bolt! Good luck in your project. Jeff | | |
#82781 09/14/2007 11:26 PM | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I took out my old babbit pounder for a 261. Horse power increases from about 92 to 150. Has the same look except for those 2 little nuts on top. | | |
