4 members (55shaker, MickeyP, 59 fleet, Gdads51), 93 guests, and 2 robots.
Topics128,118
Posts1,056,304
Members48,439
#82026 08/25/2007 10:39 PM
This problem seems simple enough, but it has me scratching my head. Last week I re-assembled the differential and rear axle on my '49 Chevy 1/2-ton truck. Specs call for 4-1/2 pints of gear oil in the back end. The first four pints went in just fine, but I was surprised when the last 1/2-pint spilled out the drain plug hole, all over the garage floor! The shop manual says the oil level should be 1/2-inch below the drain plug when the oil is cold, and full to the drain plug when the oil is hot. I'm sure everything was re-assembled the way it came apart. The ring gear is slightly off-center toward the driver side, and the drain plug is slightly below center on the back cover. Why is my capacity only 4 pints?? Do I need to fill slowly, and add the last pint on the second day?
My second question is more important than the first. How does oil in the diff lubricate the rear wheel bearings? Using a tape measure, I can tell that the drain plug on the diff cover is lower than the bottom of the axle housing. Therefore, when oil spills out the drain plug, the oil level is not high enough to fill the axle shaft and reach the rear wheel bearings. I'm afraid that no oil is contacting the bearings and I'll burn them up the first time around the block. Can somebody help me understand this??
:confused:
#82027 08/25/2007 11:04 PM
You only need to fill it to the fill hole, cap it off and drive. You don't want too much in there or it will cause a leak. The 4 1/2 pints is just a guide line not a necessity. As for lubing the axle bearings, as soon as you turn a corner, they'll get soaked and lubricated.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#82028 08/26/2007 10:53 AM
When driving, The oil will mist in the diff casing , that will lube the axle bearings.
#82029 08/26/2007 12:02 PM
AS STATED..
your bearings get lubed as ya drive ..good ol american engineerin on that !
an nothin is ever as stated in the book as far as lube it just a guide for the OlD FOLKS !..lol
1952 Chevy Shortbed
Photos in Photobucket
#82030 08/26/2007 10:58 PM
One thing you should check is to make certain that the rear axle breather is free and clean. It sits on top of the axle on the driver's side.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#82031 08/27/2007 2:48 AM
A little trick I do whan I have an axle apart, I'll apply a light coating of wheel bearing grease to the bearings and the seal. Not packing it, only a small amount to lube the bearing until the gear oil makes its way to it. The grease will mix in with the oil and won't hurt a thing.
Bill Burmeister
#82032 08/27/2007 2:53 AM
If you really wanted to "prelube" your bearings, just jack up one side some, then the other after you fill the diff on level ground,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#82033 08/27/2007 2:57 AM
Good idea, but not really practical when you got the vehicle on a lift grin
Bill Burmeister
#82034 08/27/2007 6:05 AM
Thanks folks! I guess I was worried for nothing.
#82035 08/27/2007 2:37 PM
I grease my bearings and seal too. If your worried about it, you could drive the truck over the side of a ditch to get the lube down the axle tube and into the bearings.
