3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
#812558 01/02/2012 8:58 PM
I have a new set of 8.25x20 steer tires for my 1959 C60, but the local tire shops won't touch my widowmaker rims (for good reasons). The rims are 6-stud.
What are my alternatives?
I have a good supply of 20" tires, so I'd like to run those if I can.
Are there stock one-piece rims for this year?
Will later model years fit?
Are there more modern 22.5" rims that might be appropriate?
Thanks for your input,
Jason
Jason,
There are 22.5 1 piece wheels that were an option for your 59. They are out there but pretty scares. Ford also used the same bolt pattern in the 60s. Mine for my 57 came off a Ford. Check out the tech section on this site. There is a good write up on big bolt wheels.
Shane
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Are you sure they are the widow makers or is that particular tire shop too lazy to work on all split rims in general???? Pictures?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
FYI, all 20" tires are tube type with multi piece rims. I've never seen or heard of a 20" 1-piece truck wheel. The 22.5" tubeless (1-piece) rims are the replacement size for the 20's.
Look for a BIG truck junk yard in your area and plan a field trip.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
As Scott said be sure that what you have are really widow makers. Today the tube type wheels are becoming very rare and new tire techs seem to think all two and three piece wheels are widow makers.
As Mike said the tech section here has a plethora of info on the subject.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
1 Offline
I too have 20" wheel and tire questions???? How about, does anyone know if Budd Wheel or Alcoa Wheel have a application for the 6 hole wheel pattern for the '57 2 ton truck???
Warren L. Seiz Phoenix,AZ
Talk to Les at Midway Tirecraft on Vantage Way in Delta, I'm sure he can help.
3B Offline
Hy 1size and guys, Accuride has p/n 28157 - 22.5" X 6.75", that is pretty narrow but it is a brand new wheel, hope that helps.
3B #813079 01/04/2012 5:37 AM
The rim 3B references [6.75"] will handle the 10.00 & 11.00 x 22.5" tires. These are direct replacements for the 9.00 & 10.00 x 20's. You increase your tire number one full number when you convert from 20's to 22.5's, so a 10.00 x 22.5 has the same tread width and diameter as a 9.00 x 20.
As of a few years ago when I checked, ALCOA wasn't producing any rims with our 6-lug bolt pattern.
Grigg has done a tech article on wheels, check it out!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Tech Tip
http://www.stovebolt.com/techtips/wheels/
If you want 20" or 22.5" wheels they are very common used. I can think of about a half dozen sets of 6 lug 22.5's I've seen in various yards within a hour and a half of here.
If I were you I'd go ahead and find a set of 22.5" wheels.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg, You must have some good salvage yards aroung you. I have only ever saw 1 6 lug 22.5 in a salvage yard around me and I bought it.
Shane
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
3B Offline
Hy sawnhammer, I sent you a PM a long time ago, but you don't appear to have read it yet.
