7 members (Wayne67vert, cmayna, Gdads51, Otto Skorzeny, klhansen, 55shaker, Stewart2),
169
Mod | | | Forums66 Topics128,165 Posts1,057,011 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 4 New Guy | | New Guy Joined: Jan 2011 Posts: 4 | I have a new set of 8.25x20 steer tires for my 1959 C60, but the local tire shops won't touch my widowmaker rims (for good reasons). The rims are 6-stud.
What are my alternatives?
I have a good supply of 20" tires, so I'd like to run those if I can.
Are there stock one-piece rims for this year? Will later model years fit? Are there more modern 22.5" rims that might be appropriate?
Thanks for your input,
Jason | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Jason, There are 22.5 1 piece wheels that were an option for your 59. They are out there but pretty scares. Ford also used the same bolt pattern in the 60s. Mine for my 57 came off a Ford. Check out the tech section on this site. There is a good write up on big bolt wheels. Shane | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Are you sure they are the widow makers or is that particular tire shop too lazy to work on all split rims in general???? Pictures? Scott | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | FYI, all 20" tires are tube type with multi piece rims. I've never seen or heard of a 20" 1-piece truck wheel. The 22.5" tubeless (1-piece) rims are the replacement size for the 20's. Look for a BIG truck junk yard in your area and plan a field trip. Mike B  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | As Scott said be sure that what you have are really widow makers. Today the tube type wheels are becoming very rare and new tire techs seem to think all two and three piece wheels are widow makers. As Mike said the tech section here has a plethora of info on the subject. | | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | I too have 20" wheel and tire questions???? How about, does anyone know if Budd Wheel or Alcoa Wheel have a application for the 6 hole wheel pattern for the '57 2 ton truck???
Warren L. Seiz Phoenix,AZ
| | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | Talk to Les at Midway Tirecraft on Vantage Way in Delta, I'm sure he can help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1size and guys, Accuride has p/n 28157 - 22.5" X 6.75", that is pretty narrow but it is a brand new wheel, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | The rim 3B references [6.75"] will handle the 10.00 & 11.00 x 22.5" tires. These are direct replacements for the 9.00 & 10.00 x 20's. You increase your tire number one full number when you convert from 20's to 22.5's, so a 10.00 x 22.5 has the same tread width and diameter as a 9.00 x 20. As of a few years ago when I checked, ALCOA wasn't producing any rims with our 6-lug bolt pattern. Grigg has done a tech article on wheels, check it out! Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Tech Tip http://www.stovebolt.com/techtips/wheels/If you want 20" or 22.5" wheels they are very common used. I can think of about a half dozen sets of 6 lug 22.5's I've seen in various yards within a hour and a half of here. If I were you I'd go ahead and find a set of 22.5" wheels. Grigg | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Grigg, You must have some good salvage yards aroung you. I have only ever saw 1 6 lug 22.5 in a salvage yard around me and I bought it. Shane | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sawnhammer, I sent you a PM a long time ago, but you don't appear to have read it yet. | | |
