7 members (Youngin' Tut 59, latroca52, Donf, Lightholder's Dad, Jon G, Hanks custodian, 55shaker), 73 guests, and 4 robots.
Topics128,185
Posts1,057,284
Members48,467
Socket Breaker
Socket Breaker
I have a 1965 C10.
I have the parts and the kit to replace the door pins and bushings in the hinges, as it sags a bit.
Do any of you have any tips, tricks or suggestions on what tools to use... the order of operations, etc., for this project?
Thank you for any replies.
-W
Im going to follow this thread, as I was about to post the same thing for my 63, but I wouldnt imagine that theres much difference.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
On my 64, I had to remove the hinges from the truck, cut them apart and remove the pins piece by piece. I felt that forcing things apart would have distorted something, they were stuck good. I then reassembled with the new pins and bushings,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks is spot on.
You can try to drive them out, however if they are that far gone you will be time ahead by completely removing them the truck and piecing them apart. Seems I recall going through about 4 sets before I was able to make a good set.
Pull the hinges and soak them in a pan of tranny fluid. If you have access to one, put them in a Ultrasonic cleaner. When you are able to pivot the hinge, it can be taken apart, by driving the hinge pin out, inserting the bushings & driving the new pins.
Good luck with the project.
I've had the best luck removing the doors first, then, leaving the hinges on the truck, whack the pins hard w/a BFH after soaking them w/your favorite penetrating oil. Sometimes I'll squirt them daily a couple days before I start. Use a good pin punch, cheap China ones usually won't do. Knock the bushings out w/same punch, tap the new bushings in place. Replace pins, doors etc.
Down here the rust maggots aren't too bad, I've only had to cut apart one hinge like Scott describes above in the dozens of truck hinges I've done.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Socket Breaker
Socket Breaker
Thanks a bunch folks.
-W
I live in the rust capitol of the world...Michigan, and replaced 2 sets of hinge pins. I removed them from the truck...then they spent days soaking in penetrating oil, and even though everything seemed loose it was a real chore to try and drive them out, but I was patient and finally got-r-done. Never thought about cutting them apart...which I'll try next time. Also, my new pins were cheap and too long, so I ended up cutting them and beveling the tips to look like the originals. Janine
...a generous dip in anti-sieze might help? Yep, I remember those days in the U.P. brrrrr
Socket Breaker
Socket Breaker
Well, I finally got around to this today... I could not make the pins budge on the truck, took the hinge off to whack it out, finally got it all back on... and yep, it's out of whack.
Even after I got the hinges off the truck I had the really WHALE on 'em to get them pins to even move. YIKES.
I even lined everything back up with the rust/paint marks.
Well, it's back on there and I ran out of light and motivation. I'll mess with it some more this week I suppose...
old trucks... are fun?
right?
-W
p.s. door hinge pin, wrenchin' action shots
