7 members (Slick Willy, Lostbuthaulinass, Otto Skorzeny, homer52, Gib70, BC59, 1 invisible),
115
Mod | | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79427 07/02/2007 3:08 AM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | I seem to be getting some black residue from the tail pipe. Could it be I do not have dual carbs set right? Seems to run pretty good. Any ideas would be helpful. | | |
#79428 07/02/2007 3:32 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | | | |
#79429 07/02/2007 4:50 AM | Joined: Nov 2004 Posts: 2,413 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,413 | Could be something as simple as a sticky choke or dirty air cleaner.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
#79430 07/03/2007 4:27 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Just a thought but you may have a float sticking on one of the carbs or the floats are out of adjustment. One is possibly leaking gas from the float bowl or one may have a gasket not tight enough and may be seeping down the throat into the manifold. One carb should be not working until you put your foot part way down on the gas. Too much fuel pressure could also cause it to flood and then soot. Just a few ideas that may help. Henry | | |
#79431 07/03/2007 4:38 AM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Another quick thought, I have had it happen when the needle valve was not seating correctly or was dried out and would let more gas go by than needed and caused flooding and soot like you have. Also would drip into the manifold when sitting with the engine off. Rebuilt more carbs than I can remember. Just thought of this and I hope this will help you out. This is unlikely but a carb jet inside may be not tight and letting gas go by it or it could be cracked. Just trying to come up with some suggestions. H. | | |
#79432 07/03/2007 4:42 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Most any carburated engine without catalydic converters will leave the black residue in the tailpipe. Does the oil smell like gas? Are you getting worse than normal gas mileage? Just a thought, Scott | | |
#79433 07/03/2007 1:50 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | When rubing your finger on the inside of the tailpipe this is what I would suspect.
A little dry grey residue on the inside of the exhaust is probably too lean.
Light dry black is probably pretty good.
Dry black is going to be too rich at the carb.
Wet black is oil.
I would "assume" that you are running rich with dual carbs and your discription of "black soot".
What do the plugs look like? I would use that as a more reliable indicator. | | |
#79434 07/03/2007 2:41 PM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hey guys I do not want to sound dumb, but I did think I may have been running too rich. I do I adjust? I am runnung carters. | | |
#79435 07/04/2007 5:29 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Look at your tailpipe after running on the highway for several miles, it should be a bit grey to show a proper mixture. If it's black and sooty it is definitely too rich. Read the tailpipe same as you read spark plugs. | | |
#79436 07/04/2007 7:03 PM | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Adjusting usually just takes care of the idle mixture not running mixture. Make sure that the carb screws are tight that hold it together. A 1" or a 2" spacer plate can help lean it out. Worked for me. 48 Big trucks may be on to something. If the oil smells like gas, your fuel pump may have a bad diaphragm. On Chevies and some GMC trucks, it will dump gas into the oil and in a hurry. Fuel pump time then. Just another idea. Henry | | |
#79437 07/05/2007 12:21 PM | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | At the bottom of the Carters on the side facing the valve cover, there is a little screw. To adjust my dual Carters, I turn the screw all the way in. Then I turned them out 1 1/2 turns each and started the truck. I turned in the screw until I reached rough idle then I turned it 1/4 back out. Remember, whatever you do to one carb, do to the other.
Do you have a uni-syn tool? If not, I HIGHLY suggest getting one off eBay for cheap money, your truck will thank you for it!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
#79438 07/09/2007 8:39 PM | Joined: Feb 2004 Posts: 29,815 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,815 | The only way to check high speed mixture correctly is to do a road test with a 4-gas exhaust analyzer connected. Swapping main jets and/or power valves, if your carb has them, is how high-speed mixture is adjusted. Nothing you do to the mixture screws will have any effect above idle speed. You can do a WAG by looking at spark plugs or the color of the tailpipe. A too-lean mixture will have a tendency to detonate ("spark knock") and be short on power climbing hills or accelerating. It will also run hotter than normal. Really lean, and the plugs will turn a white color, with glassy-looking deposits and/or powdery-looking shiny stuff on them as the pistons melt. Fuel is cheaper than internal engine parts, so don't get it too lean.
If anyone tells you he can change high speed mixture by adjusting the idle jet(s), one of two things is going on:
1. He's too dumb to be tinkering with your carburetor.
2. He's lying and knows it, and he's about to get into your pocket in a big way by charging you for a procedure he knows won't help.
In either case, RUN, do not walk away, and find someone who knows what he's talking about. Jerry
