5 members (Phak1, Paul_WNC, Otto Skorzeny, WICruiser, 68ironhead), 181 guests, and 9 robots.
Topics128,078
Posts1,056,036
Members48,433
#791740 10/24/2011 2:33 PM
Hello, I am swapping my 235 to a 327 V8 (1967). Can someone send me info or links on "how to engine swap" I am a new guy to this type of work. I have done a complete frame off restoration to my 50 Chevy 3100. I need to replace the broken 235. Ready to move to the open rear end (just bought '70 2wd Chevy rear end). Is there clear step by step instructions out there? Thanks
1950 Chevy 3100
with matching trailer
More pix on Photobucket
gmindel #791746 10/24/2011 3:04 PM
Most important issue would be setting the V8 in the best location, relation to the radiator, firewall etc. I do know with these trucks that the steering box will hit the exhaust header so some go to independant front suspension just for that reason.
There are also V8 motor mount kits available for this swap, check out the various vendors here and in streetrod mags etc.
1946 1/2-Ton Chevy
Dig into our Search feature and don't give up if it doesn't feed back what you want. It all depends on the wording of the search topic. Hang in there. LOTS of info in the archeives. Also check over at ChevyTalk.com. Many of us visit both sites often and they are more into guys with V8 (bent) motors. We like'm up & down here but it is a very common swap. Also Google it, etc. Bet you'll be surprised at what is out there.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I put a V8 in my 52panel. Here is a diagram of engine placement to get you started. I moved my original steering box. You may also want to visit my photobucket to get some ideas of your own.
Good luck.
Engine placement I used...and the mounts from C.E.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Engmount.jpg
