9 members (Cosmo, Samantha, Otto Skorzeny, Brian Moore, Jims46, Ponchogl, moparguy, KEVINSKI, 55shaker),
83
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I had no clock in my 53 so... Clock in gear shift knob No, I am no making these to sell, I posted the pics in case someone might like the idea and want to do it. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Very cool! where did you find the clock? | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | A friend of mine has a woodworking shop and he inserts these in novelties. He gave me the clock, I will try to find out where he gets them. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | That is awesome! Very nice work.
Jeff | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's one cool idea and a beautiful job Ron. I've had the same problem finding a place for a clock and have had a little loose analog clock rolling around the floor for five years. I would imagine that the wood worker supplies would have those just for those woodwork project that your friend is doing. Can I assume that you just press fit the housing into the bore in the knob? Thanks for posting. Actually had time to look a few clocks up. This is a nice one and appears to be similar to the one your friend found for you. A little more research and I'm sure you could come up with lots of different styles. http://www.woodcraft.com/Family/2001202/2001202.aspx or http://www.klockit.com/depts/ClockI...696&gclid=CMS_9d7n1KsCFY_CKgodACfuQA Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I talked to my woodworking friend and here is where he gets some of his clocks... woodworkingparts I got another clock from him that I am going to put on a ivory knob. Yes, it is a friction fit, the clock housing has a rubber gasket that creates the fit. I drilled a 5/16" hole thru to the threaded insert, by doing this I can use a 1/4" dowel to push the clock out. The manufacture says to drill a 1 3/8" hole, my hole was smaller, I just kept checking the fit until I had what I wanted. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ok, where'd you find the Ivory knob??? Are the vendors carrying them now?? DG
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | The ivory knob was for 36-38 Buick... Ivory Knob They have one with the threaded insert which has 3/8-24 thread same as the Chevy trucks. They are plastic but look nice, they mill a lot easier than the black bakelite. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ah yes, thanks, and once again, very cool idea. DG
| | | | | Joined: Oct 2011 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 172 | very ,very nice i think i,ll have to find a supplier of clock inserts in the uk then i can do one for my truck and matbe a few for other uk owners
nicely done thanks
live or die do it with spanner in hand
