1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#786417 10/05/2011 9:16 PM
I had no clock in my 53 so... Clock in gear shift knob
No, I am no making these to sell, I posted the pics in case someone might like the idea and want to do it.
Very cool! where did you find the clock?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
A friend of mine has a woodworking shop and he inserts these in novelties. He gave me the clock, I will try to find out where he gets them.
That is awesome! Very nice work.
Jeff
My 1953 Chevrolet
1947.1 Gallery
That's one cool idea and a beautiful job Ron. I've had the same problem finding a place for a clock and have had a little loose analog clock rolling around the floor for five years.
I would imagine that the wood worker supplies would have those just for those woodwork project that your friend is doing.
Can I assume that you just press fit the housing into the bore in the knob?
Thanks for posting.
Actually had time to look a few clocks up. This is a nice one and appears to be similar to the one your friend found for you. A little more research and I'm sure you could come up with lots of different styles. http://www.woodcraft.com/Family/2001202/2001202.aspx
or http://www.klockit.com/depts/ClockI...696&gclid=CMS_9d7n1KsCFY_CKgodACfuQA
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I talked to my woodworking friend and here is where he gets some of his clocks... woodworkingparts
I got another clock from him that I am going to put on a ivory knob.
Yes, it is a friction fit, the clock housing has a rubber gasket that creates the fit. I drilled a 5/16" hole thru to the threaded insert, by doing this I can use a 1/4" dowel to push the clock out.
The manufacture says to drill a 1 3/8" hole, my hole was smaller, I just kept checking the fit until I had what I wanted.
Ok, where'd you find the Ivory knob??? Are the vendors carrying them now??
DG
Denny G
Sandwich, IL
The ivory knob was for 36-38 Buick... Ivory Knob They have one with the threaded insert which has 3/8-24 thread same as the Chevy trucks. They are plastic but look nice, they mill a lot easier than the black bakelite.
Ah yes, thanks, and once again, very cool idea.
DG
Denny G
Sandwich, IL
very ,very nice i think i,ll have to find a supplier of clock inserts in the uk then i can do one for my truck and matbe a few for other uk owners
nicely done thanks
live or die do it with spanner in hand
Moderated by  ndkid275, Phak1
