0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | regular oil change , pre summer  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | LOL I looked at that "pre summer" and thought, "boy, he's running late". Then I saw your location.
~Jim
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | My order from Classic Parts came in... a new speedometer face, speedometer needle and gaskets. I just need to repaint the backplate before assembly. I'm in awe of the metal used in making up these vintage parts... loving it! Jerry | | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | Havent done anyting with my 1941 chevy dump truck today but I found all my pictures to show what ive done within the year I have had the truck. this is my first truck got it for $500 i thought if im goin to get my first truck mines well be a dump truck. anyway here are the pix of the project so far http://s1139.photobucket.com/albums/n542/1941chevyloadmaster/ | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Looks like you've been plenty busy on it. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I can see where it is/was and ambition project but those are the ones that gives us the most pleasure when finished. Thanks for saving a piece of American history that helped to build this country. Congrats on doing good work. | | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | Thank you. we all got to save these old girls. Keep them runng. Can't let them go to waste. Tell ya what a firrari may beat us 0-60 but strap a chain on the [censored] end of it and it ill never pull you back. 6.14:1 high 8.22:1 low two speed rear ends got it beat
| | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | And dond forget a big service on a *firrari* cost mor as a stovebolt  Jianis | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Got the bed on the '53 done and took pictures, but I'm having trouble uploading them to photobucket, so pictures to follow........
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | well yesterday I got one of 6 wheels for the 35 2 ton ready and cut in the outer edge to put on the tire and then paint it with the tire on so I dont chip it all up mounting the tire.I have about 30 hrs in it with sand blasting,welding,grinding.also got some int.parts painted,I'm getting all the black parts ready and mixing a lot of black | | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | sounds like you've been puttin the hammer down. got any pix of that 35 2 ton? | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Looking good there buddy.
~Jim
| | | | | Joined: Jul 2010 Posts: 8 New Guy | | New Guy Joined: Jul 2010 Posts: 8 | | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Removed the ignition switch from the column & filled the hole. Installed new indicator lights too.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Got the new speedo intalled. Going to go to the flaps tomorrow to get the cable replaced under warrantee, they said they'l take care of it, even though it was the speedometer that caused the failure.
Bill Burmeister | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I tried out my new cheapo HF siphon feed sand blaster and it really worked well for me... though it's not as strong or as fast as an industrial blaster. At least, I managed to blast a few heavy-rust parts... I'm anxious to try it on the frame soon. I'm also excited to complete my soaking vat! I have a lot of parts I can bundle (I'm still disassembling). I just need to be ready with plenty of primer! Jerry | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Two very productive days. Finished applying the vibration dampener inside the door cavities, installed both door latches and outside door handles, bolted the door hinge access panels on,did the final adjustment to the Lokar shifter, discovered what was causing the brake lights not to work and fixed it, and finished wiring the headlights (got high and low beams, yahoo).
~Jim
| | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Got the sound/thermal insulation (roof flashing with nice thick aluminum foil on it) installed on the doors and back cab wall. Used the heat gun to get the metal hot to the touch and the tape nice and gooey before putting it on and rolling it with the wooden roller.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Hey Farmer, how about some pics?
~Jim
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Got my OE brake and clutch pedals modified. New bushings pressed in with the new press. The hollow pins have been replaced with solid ones, drilled, tapped, and zirk’ed. I saw one picture of a set with grease fittings but never found out where they came from - possible big bolt? Anyway, mine are done. http://www.flickr.com/photos/dodsonbrett/sets/72157627774184916/Cavebull | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | made the supports for the seats, using them out of a 93 New Yorker, split with the drivers being elec. boy do the feel good, | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...dakota, I'm watching your progress. Don't go to sleep sitting in those comfy seats.
Well, for me, my nephew is finally working on my wiring harness and I think I metioned earlier I got my new style tie rod ends on the panel. | | | | | Joined: Mar 2011 Posts: 32 New Guy | | New Guy Joined: Mar 2011 Posts: 32 | Tonight i began the journey of making my truck a little safer by yanking the hydrovac to clean it up and go through it...anyone know where i can find the model number on the unit? its a 59 1.5 ton Viking. Also i will need to find a rebuild kit for it. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | She's ALIVE!! Good news: Bolter Mikestem and I cold set the valves, buttoned up all the panels, topped her off with oil and she fired right up with a single, brief stomp on the starter button! Zero hesitation even after four months of sitting with the engine half torn apart. A little trim of the choke and she purred like a kitten. Bad news: She's not getting oil in the filter or up top. Mike's guess is that we didn't get the distributer in deep enough to drive pump gear. Gonna try to fix it tonight. http://farm7.static.flickr.com/6158/6185070571_95351efee5_b.jpghttp://farm7.static.flickr.com/6152/6191905703_edfd5bafd6_b.jpg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Installed the door lock and those two doodads that go at the top and bottom of the interior windshield center molding. Also installed the drivers sun-visor.
~Jim
| | | | | Joined: Sep 2011 Posts: 25 New Guy | | New Guy Joined: Sep 2011 Posts: 25 | wire wheeled the driver side running board and finder then painted them. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Farmer, what's that contraption on your floorboard? Does it work with your seat?
~Jim
| | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | I think the number is on a tag on one of the bolts on the unit.
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276 "If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
| | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Farmer, what's that contraption on your floorboard? Does it work with your seat? Those are my precision engineered seat mount brackets. I found a 3rd row seat out of a Dodge Caravan, perfect fit on the frame. It has a quick release system on the rear that will latch on to those bolts you see. It also has a lever to fold the seat back forward and another lever to slide the whole thing forward on it's integral tracks. Pretty good solution for $75. Sold my velour buckets it came with on flea bay for $55 and this will look more authentic and should be cheaper to re-upholster. And yes, when it's in I'll post some pics.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | LOL looks like you're getting well trained.
~Jim
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Spent several hours on each of the last 3 days yanking on the right side bumper bracket to frame bolts. Finally had to cut them flush and try the old "heat & beat" routine. Another hour and a half later I'd moved one of them just over an eighth of an inch. Arrrggh! The big drill is next. | | | | | Joined: Aug 2011 Posts: 18 New Guy | | New Guy Joined: Aug 2011 Posts: 18 | 49 Chevy 3600. Changed oil & filter and replaced spark plugs. | | |
