3 members (DoubleB, J Lucas, Phak1), 48 guests, and 1 robot.
Topics128,091
Posts1,056,033
Members48,433
#766677 07/29/2011 4:05 PM
well gents, i ended up selling my 39 1/2 ton and got a 38 1/2 ton. it has the 235 motor, automatic tranny, the guy had put a different ear end. when i got it it needed some repairs to make her run, i had the gas tank cleaned, carb rebuilt, i checked fuel pump. starts up. my sons help me on this one too...
QUESTION: automatic tranny does stop on park. it still moves, the old man told me cabling issue/?????
http://i186.photobucket.com/albums/x315/oldmemoriescc/0728011841.jpg?t=1311951791
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
oldmemoriescc #766688 07/29/2011 5:02 PM
Depends on what tranny set up you have. It may be that the linkage needs adjusting to let it go all the way into park. I'd put wheel chocks under all the wheels, or put it on jack stands, and disconnet the rod to the lever on the side of the tranny. Then see if the "arm" will move into the park position and if it does then see if the wheels spin or not. If they don't then adjust the lever/rod to the "arm" on the tranny and you should be in business....depending on what your running or if its a aftermarket kit that you can adjust...or you may have to buy one.
I should have ask if its on the column or in the floor!!
Achipmunk #766773 07/29/2011 11:29 PM
Like Alvin says, good chance it's in the linkage. I've done a few homemade setups, and getting the rod just right is tricky. Good news is, nowadays you can buy an adjustable shift linkage setup. But, are you using a floor shift or a column shift, and what kind?
Sorry to see a '39 go away, but that '38 it Sharp!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #766992 07/30/2011 11:05 PM
Nice looking 38!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #767046 07/31/2011 2:35 AM
Good Looking 1/2 ton!
Gmans 46 #767395 08/01/2011 11:19 AM
Joy Offline
Welcome!
Joy #767428 08/01/2011 2:19 PM
thanks to all, i am still working on the truck, my sons and i put the gas tank on, redid some gas lines and today will give it a tune up. as for the shifter, from my understanding its a camaro shifter on the floor. i did see the cable that leads to the tranny which is all home made, i will try to adjust it.
thanks to all
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
oldmemoriescc #767876 08/02/2011 4:33 PM
Very nice truck you got there.
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
CGG_64C10 #770263 08/10/2011 3:00 PM
thanks...im going to replace the fuel pump. anyone have one with a glass bowl for sale?
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
oldmemoriescc #774479 08/24/2011 1:59 AM
Now that is Art Deco!...no matter what Chevrolet says! Sweet!
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
