1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Looks like the tailgate says GMC.
Also, guessing 41-47 due to the fact that the riveted supports for the fender are located directly in the center of the fender. I believe earlier models had the fender support about 3/4 of the way to the rear of the fender.
I think as long as the fenders aren't rusted through the flanges they are easily worth $50, Just my opinion.
Jeff | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Thanks for info Jeff...and good eye on the GMC on the tailgate. I think you may be right about that, too bad as I was hoping to use the tailgate as well.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | The fenders look wide. 1939 ONLY fenders are wider than the '40-'47 fenders. The bed for '39 and earlier is only 45 inches wide as opposed to 48 inches for '40 and later.
Mike | | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Thanks for the heads up Mike. I emailed the guy and he is going to measure the width of the tailgate in the next day or so and get back with me. Come to think of it, the tailgate seems embossed with GMC which would make this box more that likely a 1939 or earlier. Looks like I may have to keep looking.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | i WOULD BUY THAT IN A HEARTBEAT! Those tires in the back are worth $50. Buy it! Worst case scenario: none of the parts fit your truck and you have an extra trailer. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | For $50 I would jump all over that. If nothing else it would be a cool trailer to pull with your truck when you get it done. | | |
