0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 27 New Guy | | New Guy Joined: May 2011 Posts: 27 | Hello, starting my resoration and wanted to see if anybody had any advise on how to remove the dashboard in my 1952 GMC 150. A step by step would be nice. My goal is to paint the dash out of the truck with no guages and knobs so I get a nice clean finish. Your help is appreciated.
1952 GMC 150 3/4 ton 5 Window
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The dash is non removable, it's part of the cab structure and welded in place. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Lots an lots of work, usually only done if butchered or rusted. | | | | | Joined: May 2011 Posts: 27 New Guy | | New Guy Joined: May 2011 Posts: 27 | Oh ok. Mine isnt bad, just wanted it out for convenience. Thanks guys.
| | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | can be done . spot welded across the windscreen opening and at the pillars as well as bolts under the dash at both ends . removed mine to do left right conversion and to fill all the old holes, dash, speakers and glovebox etc. not that big a job just be carefull drilling out the spot welds. dash will need to be reinstalled so I wouldn't paint finish it . repair it put it in primer then reinstall | | |
