0 members (), 51 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#750143 05/27/2011 9:38 PM
Hello, starting my resoration and wanted to see if anybody had any advise on how to remove the dashboard in my 1952 GMC 150. A step by step would be nice. My goal is to paint the dash out of the truck with no guages and knobs so I get a nice clean finish. Your help is appreciated.
1952 GMC 150 3/4 ton 5 Window
The dash is non removable, it's part of the cab structure and welded in place.
DG
Denny G
Sandwich, IL
Lots an lots of work, usually only done if butchered or rusted.
Brad Allen #750911 05/31/2011 4:16 PM
Oh ok. Mine isnt bad, just wanted it out for convenience. Thanks guys.
U
U Offline
can be done . spot welded across the windscreen opening and at the pillars as well as bolts under the dash at both ends . removed mine to do left right conversion and to fill all the old holes, dash, speakers and glovebox etc. not that big a job just be carefull drilling out the spot welds. dash will need to be reinstalled so I wouldn't paint finish it . repair it put it in primer then reinstall
Moderated by  ndkid275, Phak1
