| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've got a nice valve cover with the exception of someone chrome plated it. What's a good and or easy way to remove it prior to painting?
Looks like it may only be chrome, no copper, and I'm not sure about nickel.
Grigg | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I've used 80 grit to unchrome a bumper. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Give it to a kid and tell him not to take the chrome off... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm not excited about using abrasives because of the detail in the letters, overall it's already clean and straight and I don't want to remove any more material than necessary.
What does a chrome shop do before replating something that was poorly done to start with?
Grigg | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | I managed to prep a valve cover for paint/POR-15 in a floor standing sand blast cabinet. It made all kinds of funny sparks when the abrasive hit the chrome but the fairly fine abrasive left just enough key to make a good bond, no distortion that I could see took place. It was more a surface roughening than a material removal. Perhaps try your abrasive of choice on a scrap of something of similar weight before your valve cover? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe they do it chemically but I might be wrong. If it's sticking just abrade it and paint over it.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | all you have to do is cut the gloss enoughto provide tooth for a good primer
chrome shops hand grind old chrome off, that's why it's more expensive to RE-chrome something
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Reverse electrolysis is one process that some plating companies use, another is the use of Muratic acid solution. If I remember correctly, brake fluid was never a friend of chrome either! Contact your local plating or powder coating company and ask to hear their method of de-chroming. Another thought is to trade with someone that would love to have a chromed valve cover. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I was watching Powerblock this weekend and they had a segment showing Advance Plating in Tennessee that was flooded last year. They put their parts is a caustic bath to strip them. I don't know if that's SOP or was just used on their parts.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Use a good self etching primer, something that'll bite into the surface after you scuff it like squeeze said. On aside note, it most likely does have a nickel base, that's wha actually gives "chrome" it's color. The chrome part is actually a very thin layer that's used to prevent corrosion in the underlying layers.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...most shops "serious" about de-chroming will use chemicals. its a different world but for 13 years we plated nickel, copper and hard industrial chrome on top of the copper. To dechrome a print cylinder we ran hot water over the cylinder and then poured muriatic acid on it.....chrome gone! Its some nasty stuff though and anyone trying it should wear a respirator and be very careful.... .watch where you throw those dirty rags.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I was going to mention muriatic acid also. I don't know about chrome, but I poured some through a regular metal funnel and it took the shine right off of it. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Have a chrome place de-chrome it, or get a different one. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'll see what I can do. It's derusting now, I'll deal with the chrome next. It was left outside upside down with pieces parts in it for quite some time before I got it, inside was rusted pretty bad but looks to be cleaning up quite nicely.
It's a reasonably rare valve cover for my Detroit 4-53. Early on they made them just a few years that said "General Motors Diesel" then after the company name change all the later ones say "Detroit Diesel". I'm not likely to find another one any time soon, at least I haven't yet in the several years now I've had my eye out for Detroit parts.
Grigg | | | | | Joined: Sep 2007 Posts: 141 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 141 | I think that if you take it to a chrome shop, they will remove all of the rust and the chrome at the same time. Chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Rust is about gone, or so I hear. Ill get it back sometime soon and post some pictures. Not knowing what to do with the chrome from the start I figured the rust was manageable so tackle that first. Good to know for next time that it may be a two for one deal!
Grigg | | |
