| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74606 03/10/2007 11:01 PM | Joined: Feb 2006 Posts: 13 New Guy | | New Guy Joined: Feb 2006 Posts: 13 | Thanks to all the help on this forum, last fall I was able to figure ouy that the flexplate in my transmission needs to be flipped. I have a 283 with a TH350. Now that it is finally getting warmer and spring-like I can tackle this project. I want to get bout the engine and tramsmission out at this time. Correst me if I am wrong but the engine and transmission come out together, right? What is required to take the trans off, them the flexplate? Thanks for answering my rookie questions. | | |
#74607 03/12/2007 7:33 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i don't mess with automatics much but i have pulled several. i would do them seperatly. pull the engine first. unbolt the engine from the trans on the outside, take the pan off the bottom and unbolt the flexplate frome torque converter. you'll have to turn engine to take one bolt at a time. take engine out as normal then trans. if you leave the converter in the trans you won't crack it. you could do it together prob but a lot heavier and a heck of a angle. i have had trans hang up on crosmembers. good luck. usually you mark it to make sure it goes back the same but if you are changing the plate i guess not. hr | | |
#74608 03/12/2007 7:34 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | oh i forgot it was on a c10 you will prob have room. you could always take front sheetmetal off too. | | |
#74609 03/15/2007 1:13 AM | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | You do not need to pull both. You only need to remove one or the other. I would pull the transmission. The flexplate can then be removed from the engine. | | |
#74610 03/15/2007 4:18 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | A friend of mine decided to pull the tranny out with the engine. When it was out of the truck. the tranny bumped the windshield. You know the rest of the story.
I remove components like the fuel pump and carb too just so it doesn't interfere with the chains or load leveler and break something. It's probably coming apart anyway isn't it? | | |
#74611 03/15/2007 5:33 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Go take a look at how many bolts hold the front end off the truck. My dad has an 80s chev truck and when he pulled parts he said it took no time at all to pull the front end off and remove engine and tranny as one. Then again he has the sm 465 which weighs a heck of a lot more then an auto...
Last time I had to hook up an auto while under the truck I woulda made a sailor blush with all my colorful sayings... | | |
#74612 03/15/2007 6:18 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm with lucforce; Drop the driveline first, then unbolt the tranny. You can rent a tranny jack at any good rental place, well worth the $$. | | |
#74613 03/15/2007 7:03 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | How is working under the truck going to make much difference when the front end is off? I would think removing the front end is still a lot more work than unbolting the tranny from the engine.
If you are working on the engine, pull the engine. If you are working on the tranny, Pull the tranny. You'll save time over removing both and/or the front end. | | |
#74614 03/15/2007 7:41 PM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | i would drop the tranny first, then pop the hood out.. you probably just need to pull the hood off.
#74615 03/15/2007 8:40 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Pull the engine alone, if you are using a shop crane you don't even have to pull the hood. Or if you like lying on your back, slide the trans back using 2 long bolts in the bellhousing, & remove the flywheel w/o pulling anything out. Brian | | |
#74616 03/15/2007 9:54 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | If you can rent a trans jack just pull the auto...doc | | |
