1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#735184 04/01/2011 7:17 AM
Guys, I tried the search function without success.
I'm finally going to get hoses made for my MII rack to Chevy Saginaw pump.
Which port goes where?
i.e. which is feed and which is the return on the rack?
More pix on Flickr.
I can't help except with a couple ideas...
Stroll through a yard and seek an MII or Capri with the same rack and look, or find a set of original hoses. The ends should be different sizes and will only go on one way.
Last resort, hit the library and look for a Mustang repair manual.
Sorry, just saw where you are hunting from! Did any of the european fords use the same rack or pump? If so, you can compare with them.
Hi Jock......I will have a look at mine this evening and post info. When I did mine, I was able to purchase premade hoses from a rod shop - probably not an option for you in merry old England *g*
1940 Chevy KC 1/2-Ton
Britcon #735376 04/01/2011 11:43 PM
OK...had a look at my rack which is an original production unit. Looking down from top side ( input shaft on top ), and from front of vehicle, the supply line is the lower fitting on right side, and the return line is the upper fitting on right side.
Britcon #735441 04/02/2011 3:28 AM
...and if you get them backwards you will know it. The steering wheel will go crazy...and break your wrist if you have your hand on it.
Thanks for looking for him Bruce. I was heading out to the shop to look at mine.
Achipmunk #735487 04/02/2011 5:23 AM
1 Offline
Yes...I remember it well, "It happened to me" big_eek
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Highflyer #735529 04/02/2011 7:39 AM
Thanks guys,I knew you would point me in the right direction,(pun intended)
Stroll through a yard and seek an MII or Capri with the same rack and look.
I think the F*rd Granada here used a similar unit,although I've already got a guy lined up to make my hoses,I just didn't want to mix things up!
I wasn't sure what would happen if I got it wrong,I guess Alvin and Todd found out for me....... drive
Thanks for looking Bruce(britcon)
More pix on Flickr.
Achipmunk #743251 04/28/2011 7:53 PM
You'll never guess what I did today........ blush
At least I didn't break anything.
I should have read Bruces (Britcons) reply properly!
More pix on Flickr.
jockbolter50 #743278 04/28/2011 10:09 PM
Sounds like Murphy is alive and well in the U.K.!! I mean, even without asking any questions you have a 50-50 chance of getting it right the first time!! Oh well, that's the way it usually goes with me too.
waldo53 #743387 04/29/2011 7:28 AM
You've got that right Waldo!
Thankfully I've got enough slack in the hoses to rectify the problem.
More pix on Flickr.
Got 'er done! Steering's now nicely weighted and smooth,and NO leaks!!
Have a look.(poor quality sound)
More pix on Flickr.
That's one mean-looking AD you got there, she's comming along great. Glad you got 'er going, keep us posted on your build.
