5 members (2-Ton, 39suburban, pauld, 2 invisible), 176 guests, and 5 robots.
Topics128,186
Posts1,057,305
Members48,467
Page 36 of 177 1 2 … 34 35 36 37 38 … 176 177
Installed new valve springs on the cylinder making noise,the exhaust spring was very weak and now most of the rattle is gone so I ordered 10 more springs and will replace the rest. Lesson learned here is when rebuilding a motor replace the valve springs.
...worked on my friends 2000 Stovebolt and then washed the 37 and took it for a SPIN! Back to the panel next week!
Fabricated a set of tailgate chains with 1/4" chain, add-a-links, and heavy carabieners. It works great, and was a helluva lot cheaper than buying the kit!
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
Fitted my electric wiper convertion ( bolted right in perfect ).
Fitted electric cooling fan with thermostat (will keep the water pump mounted mechanical one too) Stripped out old wiring loom and started thinning out the ez wire kit ready too go back in its place. Still need too scorce a Alternator and coil to complete 12 volt converstion
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
Got the seats sent off to the upholstry shop. Need to order some parts for the interior. Got the radiator back from the shop but he did not think to call me about making it modern high pressure. Now I'm thinking about sending it back and having it converted. With the five jug intake on it I might need the extra heat. Still wrestling with that one. I hate making decisions.......
Got my gas gauge fixed today. So excited, i can finally get rid of that wooden stick for measuring the gas.
WOO HOO!!
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
WOO HOO!!
That's a good idea until mine gets fixed...
Alex
Well, finally started tackling the brake situation again on the panel. I did get ONE of the two leaks stopped and a trip to NAPA tomorrow for some weatherhead/eaton fittings and I should be in business......that is if my eye appt. goes well and I can still see what I'm doing.
Got my glass run channel in with a rivet and my glass. Tomorrow the vent window will go in.
~Jim
I got the front bumper of my big bolt rollback close to around 4" off the floor! Everything was surprisingly easy right up to the point of hooking up the steering linkage. Still figuring that out.
Even a fool is thought wise if he keeps silent, and discerning if he holds his tongue. proverbs 17:28
Finished tidying up and painting my freshly welded engine and strut rod mounts.
Put the steering rack and hoses in for the last time(hopefully!)
Made and installed a new M/C return spring mount.
I will re-fit the steering shafts,exhausts and bleed out the steering pump today,it'd better not flippin' leak!!!
More pix on Flickr.
Looking good!
~Jim
Guess who mixed up his P/S hoses! blush
Especially as I started a specific thread regarding the subject........
darn near broke my thumbs!
It just goes to show, READ the replys correctly. dang
More pix on Flickr.
Dang Jock, didn't you read Todd's warning about what happens when you do that? The question is, does it leak?
~Jim
Looking very good chug
Jianis
That's my point,from Alvin and Todd's reply I knew what would happen, I just mis-read Bruces (britcon) reply.
Thankfully it didn't do any damage,and no it didn't leak! grin
Scared the carp out me though.....
I did however manage to spill fluid down the front of the engine,the pump's mounted low on the left of the engine,right below the alternator mount.
It's hard enough just to get the cap off!
More pix on Flickr.
Todd said his was not damaged, just his underpants. big_eek
~Jim
Wiped off the dust,checked the fluids,gauged the tires - ready for a "cruise in and show" Friday nite and Saturday.
And the pucker mark on the seat!
More pix on Flickr.
Well I got the P/S hoses sorted, so here's the proof! (Poor quality)
More pix on Flickr.
Looks good Jock. Congratulations!!!
Was that William and Kate sitting in bed wink
Cool neighborhood...
~Jim
Thanks.....funny though, I never noticed the newly weds in the back,they must've fell out when I nailed it! drive
You'll notice how quickly I settled into the 'obligatory' arm out the window too.
Good thing is my work van is RHD and the truck LHD,so i'll get a more even 'truckers tan' this year!
We do actually get sunshine..... look!
More pix on Flickr.
Well, I got most of the e-brake assembly off and cleaned (under my new lift installed last week) so I could adjust it and get my e brake back. So much undercoat you had to dig to find it. Got allllmost finished when the last (mangled and rusted) bolt broke the screw end of the right rear cable as I gently (sort of) tried to remove it after 40 useless applications of Kroil
failed to even touch it. Oh well - wait for the new cable and finish up when it gets here. Now I know why the e brake has never wanted to work, at least in my time. Dale
Last night I filled up my plug holes with ATF to try to get the engine unstuck and then began the clean-out of the interior.
The floormat and pad got ripped out. I took the shop vac to everything I could reach without removing the seat and the truck smells much better now without its cargo of mouse turds. Along with the turds I found at least seven dried out mice under the seat and in the cab corners.
You older guys must get your grandkids to clean out the cab corners for you when they won't stopping bugging you while you're working on your bolt. That is a pretty gross job and small hands would be an asset. wink
Dallas Huybregts
Sherwood Park, Alberta
1951 Chevrolet 1300
email
Photobucket
flickr
Waxed mine with The Wax Shop Super Glaze. Don't even know if they still make it; bought this bottle maybe 10 years ago.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Drove alllllllllll the way to Turlock to get my new windshield!!!! woooohooooo.... thanks Jim!!!!
Now you're just showing off, you actually wax your truck? grin
More pix on Flickr.
One little step at a time. Yesterday I marked for and drilled bolt holes for the air conditioner evaporator unit. Today I managed to hook up the remote control for the door opener and hook up a 1" hose to the cowl vent drain which I will be running down and over to exit at the passenger side toe-board.
http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/?action=view&current=P4300354.jpg
http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/?action=view&current=P4300355.jpg
http://s729.photobucket.com/albums/ww296/BIGCHEVY3600/?action=view&current=P4300356.jpg
~Jim
Finally got the garage organized but still haven't had my truck shipped here yet.
Robert C.
I'm a Genius in the making.
1950 3600
I drove it!
'57 Chevy Suburban; '70 Chevy Impala.
went out to fix the "no brake lights" people keep flagging me down to tell me. Every time I go to fix them they are working perfectly. ARGGH!
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Bend up some new fuel lines with some 5/16 copper tubing. Truck has way better fuel pressure now that it is not sucking in air and pushing rust in the carb. Also added a filter to the carb.
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1562
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1561
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Installed new plugs, wires, coil and bracket, painted and installed the stomp start mechanism, motor and generator mounting brackets, carburator linkage, painted and installed the starter, oil filter cannister and painted the generator with plans for installation this evening after work. Whew... I reckon I've been busy. laalaa
I'm anxiously awaiting for the fuel pump to arrive. I have to fab up a fuel line from pump to carb, and a vacuum line from distributor to carb.
At this rate you'll be finished this week. thumbs_up
~Jim
Got the emergency brake cables and assembly back together after many, many hours of cleaning tar and rust - man they were a mess - got it down off the lift - drove it a while - ebrake still not working - back up for more adjusting this morning. Seems such a small thing, but then-- will feel good when it finally works right.
Dale
Ordered a new dimmer switch. Discovered mine was bad while driving home from a cruise in Saturday nite. Wiped off the bug glub and just looked at the truck for a while. Seriously thinkin' about some modifications. Just have to think about it some more.
The ‘53’s hood is painted and ready to install! Hopefully tonight I’ll get it bolted on.
The ’66 is back at the paint shop getting painted the correct color this time. They are also doing some additional body work to a few dents they missed the first time. I should bring it home some time this week.
The ’65 got a new tach mounted below the dash.
More pictures to follow…………………
http://s783.photobucket.com/albums/...%20pickup%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Installed the generator and fan belt and plumbed in the bypass oil filter. Carb is in transit and should arrive today!
I'm THIS close to getting to the tranny and buckling it all together.
I had a dream about my truck running last night... sweet.
