0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Hi I have not posted here in a long time. I have a 38 GMC(same as a Chevy)I adapted some original brake and clutch petals to the frame put power disc brakes on my truck. here is my question, how close can my power booster/master cylinder be to the exhaust with out it causing some kind of a heat problem with my master cylinder. ya I know it is a design flaw on my part and I am going to fix it I just need to know how far the minimum distance is so I can fix it right the first time. Also would a heat shield of some kind help me any
1938 Gmc 1/2 ton
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | To answer your question, I don't know how close is too close but my exhaust pipes were too close for me. I had three areas that concerned me. Master cylinder, the rubber brake hose at my third member, and both pipes are very close to my gas tank. I solved my heat problems by purchasing several different lengths and sizes of fiberglass with a silicon coating sleeving. It's used to protect hydraulic lines on welding robots to keep the sparks from burning through the lines. I split it, wrapped the offending areas of exhaust pipe and clamped it with sst wire ties. Smaller size got used on the rubber brake line.
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ....have a V8 in my 37 with the m/c-booster under the floorboard. I have the exhaust from a midly hopped up 350 going just under it. I've had no problems in the past 10years. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | That works for me Achipmunk, I just know I noticed how close it is and wondered if I was going to have a problem
Thank You
1938 Gmc 1/2 ton
| | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | Achipmunk, I am looking at adding a m/c-booster under the floor of my 37. Was wondering if you had any pictures and or suggestions from your setup.
Thanks | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | unfortunately I lost a roll of film back when I did the 37. However, you can take a look in my photobucket below and see how the 52panel is set up. While not "exactly" the same they are basically. If you want, I can slide under the 37 and take a few pics but it is not "store bought" but fabricated by a friend. Back then I did what I had to do but if I would have had the money back then I would have bought the kit. I purchased the brackets, pedal,booster,M/C (the entire deal) for my panel this past year from Piratejack.net for $207. I do believe they carry a set up for yours but not sure.
Let me know about the pics. I can get some tomorrow or tomorrow night. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm experiencing similar problems with my '50. A V8's a tight fit in an AD,never mind a '38! I've just ordered a pair of these for the M/C and the area near the starter.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | My exhaust is about 6" away from the master cylinder and booster. Been that way for 20+ years with no problems. Good suggestions from the other guys about using a "heat wrap material" on the exhaust. Good for piece of mind. | | |
