5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
#738698 04/13/2011 12:59 AM
having trouble getting the drums to come off> have removed wheel and flat head bolts> rocks a little but wont come out.
tanks
Did you run the adjusters as loose as possible? Old drums may get a ridge around the inside. If they are Huck brakes (should be) there are 2 adjusters per wheel cylinder. Both ends are RH threads. Looking end-on the cylinder, turn the star wheel counter-clockwise to loosen the shoes.
If they appear to be sticking in the middle you need to strike them with a hammer where they are backed by the hub. You can also try turning the drum as you pull on it.
1951 1 Ton Completed
If I remember right, mine would not come off because of the "lip" even after backing off the adjusters. After prying with no luck I unbolted the cylinder itself and let it fall inside. For me, the drum came right off then. Not sure if anyone else would do that, maybe someone will confirm.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
You also removed the two screws holding the drum on as well right?
