| | | Forums66 Topics128,162 Posts1,056,924 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 39 New Guy | | New Guy Joined: Feb 2011 Posts: 39 | having trouble getting the drums to come off> have removed wheel and flat head bolts> rocks a little but wont come out. tanks | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Did you run the adjusters as loose as possible? Old drums may get a ridge around the inside. If they are Huck brakes (should be) there are 2 adjusters per wheel cylinder. Both ends are RH threads. Looking end-on the cylinder, turn the star wheel counter-clockwise to loosen the shoes.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If they appear to be sticking in the middle you need to strike them with a hammer where they are backed by the hub. You can also try turning the drum as you pull on it. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | If I remember right, mine would not come off because of the "lip" even after backing off the adjusters. After prying with no luck I unbolted the cylinder itself and let it fall inside. For me, the drum came right off then. Not sure if anyone else would do that, maybe someone will confirm. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You also removed the two screws holding the drum on as well right? | | |
