0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | When i dismantled the bed off the truck the bed angle rails (that set on top of the wood bed) were basically gone and rusted away.
however what did remain was enough to show me that the had been spot welded in place.
I'm wanting to buy some new black steel bed angle strips and re-weld these to the side panels before paint...just gotta make sure they are at the right elevation to set on top of the wood bed once installed.
Does anyone have a dimension regarding placement of these?
thanks | | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | On my '37 bed the front and rear panels have a inset where the wood sets and the side pieces set set right down on the wood itself. I think you need the wood to set the side pieces, at least thats the way I did mine.
Joe | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Do any of the cross-rails bolt to the bed sides? If so, the angle strips need to leave room for the bed wood between the cross rails and the strips. Remember, take into account any milling done on the edge of the boards under the strips. Sorry I don't have specifics, but that's the geometry of the situation.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I would procure a piece of the wood, or a similar wood, with the correct thickness AFTER MILLING and use it to set the bed up the way you want it. Just reading the way Joe H has his set is not like mine is so there may be a few choices.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Have you checked with MarK to see if they have a replacement strip? http://mar-k.com/
~Jim
| | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | I am going to have to go look at mine now, maybe I am all wrong on how it went together. Joe | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Moondoggie,
I think I have what you need. I have '51 1/2T which is short bed - yours is same thing but long bed. I took mine off last week and measured from the fender attachment bolt holes down to the angle.
I have pictures that I can post tomorrow with the dimensions.
Paul | | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | absolutely cool...thanks a bunch | | | | | Joined: Sep 2010 Posts: 1 New Guy | | New Guy Joined: Sep 2010 Posts: 1 | The article in Hot Rodders by Bruce Hokey explains a bit of detail, but i'm certain if you send him a quick note, he can give you exact dimensions. | | |
