2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#726440 03/04/2011 3:03 AM
When i dismantled the bed off the truck the bed angle rails (that set on top of the wood bed) were basically gone and rusted away.
however what did remain was enough to show me that the had been spot welded in place.
I'm wanting to buy some new black steel bed angle strips and re-weld these to the side panels before paint...just gotta make sure they are at the right elevation to set on top of the wood bed once installed.
Does anyone have a dimension regarding placement of these?
thanks
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
http://flic.kr/p/8RQvKZ
On my '37 bed the front and rear panels have a inset where the wood sets and the side pieces set set right down on the wood itself. I think you need the wood to set the side pieces, at least thats the way I did mine.
Joe
Do any of the cross-rails bolt to the bed sides? If so, the angle strips need to leave room for the bed wood between the cross rails and the strips. Remember, take into account any milling done on the edge of the boards under the strips.
Sorry I don't have specifics, but that's the geometry of the situation.
I would procure a piece of the wood, or a similar wood, with the correct thickness AFTER MILLING and use it to set the bed up the way you want it.
Just reading the way Joe H has his set is not like mine is so there may be a few choices.
Have you checked with MarK to see if they have a replacement strip?
http://mar-k.com/
~Jim
I am going to have to go look at mine now, maybe I am all wrong on how it went together. Joe
Moondoggie,
I think I have what you need. I have '51 1/2T which is short bed - yours is same thing but long bed. I took mine off last week and measured from the fender attachment bolt holes down to the angle.
I have pictures that I can post tomorrow with the dimensions.
Paul
absolutely cool...thanks a bunch
Hank Flowers
Cut and Shoot Texas
1952 3/4 Ton 3600
The article in Hot Rodders by Bruce Hokey explains a bit of detail, but i'm certain if you send him a quick note, he can give you exact dimensions.
