0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
I need to remove my driverside latch assembly from the door so I can replace the spring that holds up the outside handle . I got all the screws out and the outside handle off , the latch is loose and wobbles around but I can't see whats still keeping it from coming out .
The steel window channel guide needs to be removed as well. There are two screws that are about 1/2 way down on the door and sometimes another one inside just below window level holding it in.
Don't know if this will help but maybe. Scroll down to the 49 manual and take a look....along with what Brad says.
http://chevy.oldcarmanualproject.com/
Please let me know how this works out. I mean. How you replaced the spring. Did this resolve your problem. And where did you get the spring.
I have the same problem with only my drivers door's outside handle.
Dennis
Ok , I got it . It was the channel blocking it from coming out . I seen these springs in the "Classic Parts" catalog for $4.95 - told my buddy I needed to get one and he gave me a handful of the coiled type springs said "see if one of these works" I lucked out and now it works great . My old spring was broken and half gone - its a wonder the handle came up at all before !
Sounds good. I have the drooping drivers handle on my 48 and wondered if spring replacement was worth it.
Dennis
