1 members (JW51),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I need to remove my driverside latch assembly from the door so I can replace the spring that holds up the outside handle . I got all the screws out and the outside handle off , the latch is loose and wobbles around but I can't see whats still keeping it from coming out . | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The steel window channel guide needs to be removed as well. There are two screws that are about 1/2 way down on the door and sometimes another one inside just below window level holding it in. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don't know if this will help but maybe. Scroll down to the 49 manual and take a look....along with what Brad says. http://chevy.oldcarmanualproject.com/ | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Please let me know how this works out. I mean. How you replaced the spring. Did this resolve your problem. And where did you get the spring.
I have the same problem with only my drivers door's outside handle.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | Ok , I got it . It was the channel blocking it from coming out . I seen these springs in the "Classic Parts" catalog for $4.95 - told my buddy I needed to get one and he gave me a handful of the coiled type springs said "see if one of these works" I lucked out and now it works great . My old spring was broken and half gone - its a wonder the handle came up at all before ! | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Sounds good. I have the drooping drivers handle on my 48 and wondered if spring replacement was worth it.
