11 members (Buckeye998, treegrower, carbking, dt235sd, Phak1, Rusty Rod, Gdads51, Bill Hanlon, 68ironhead, GMCJammer51, 1 invisible),
379
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Does anyone know exactly where the optional bullet shaped tail lights are mounted. apparently there is a template avaiable. Most of the ones I've seen are about 4" below the belt line and as far back as possible | | | | | | Anonymous Unregistered | | Anonymous Unregistered | hay '53, there is a template for placing the tear lights on the side. tclederman sent mine to me over the internet. maybe, he'll do the same for you.
tony'n weatherford | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Tim has the template on his web site. I used it recently when I put them on my Suburban. Check the directory to find his web site.
I printed a copy, cut it out, and was careful to use the printed side first, then using the holes I made to mark the holes as reference to do the other side.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Tim, thanks a million for the template. It's just what I needed Leo | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | anybody know where to pick up a set of bullet lights at a deseant price.
layback
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What's a decent price? $175 for a pair? Reproductions are now available from several vendors and on eBay. Be sure to get the two-filament bulb version if you want tail/stop/signal. Jim Carter has them, for example. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | thank you. yes i have sceen the ebay ones.just checking to see what's out there.
layback
| | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | I spent a lot of time and energy trying to find a pair at a "good" price and was encouraged in this forum to "bite the bullet" and buy new ones. I bought a pair for about $165 and very glad I did. They are very well built and the least of the expenses associated with a rebuild. Good luck
All the best, Ted
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I bought one pair at a swap meet and another as part of a parts truck. Both sets needed work and I would probably have spent less if I just bought new ones...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I bought my lights for $170. They are in excellent condition and are not repops. They have the double filament bulbs. I was surprised how heavy they are. | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | I just purchased a repro set. VERY well done,129.00, glass blue dot lenses,double filament sockets,nice chrome trim ring,heavy gauge body. Marty | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | Marty, Where? Commercial vendor (name please)or swaps? | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | Got 'em on evil bay. "Baileys Garage". Theyre the same repros everyones selling,,he's got everyone beat,pricewise. | | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | I got mine from Wheels of Time for $98.00 out of Philadelphia Ms. phone #601-389-5880. I haven't been on there web site but it is WWW.wheels-of-times.com | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I was ready to drill the mounting holes for my bullet rear lights using the template that Tim sent me. Well, my lights are apparently not the correct ones. They match the contour of the truck body perfectly, but the mounting holes are 5 inches apart and beside each other rather than above each other. The unit is about an inch longer than the correct one. The stainless bezel and lens are identical. Is this likely off an old car or wagon? Did the lights change during the '47 - '53 series? It does have a GM part number on it, 922144, it also says Guide made in USA. Also says OLDSIG on the top as well as the lens. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You actually have a Oldsmobile or Pontiac light. The Bullet lights that you are looking for are found on 1939 Chevy cars, 1949 - 52 Chevy/Pontiac/Oldsmobile wagons and 1948 - 1955 Panels, Canopy Express and Suburbans. Check your email. ..g | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think the unit for a Chevrolet car is a single filament lamp, but it is the same size and same mounting bolts as for a 47-55 panel body truck tail/stop lamp RPO. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The 1939 tail lights also used the double filament 1154 lamps. The only difference between the tail lights is the length of the wire, the panels used a longer pig tail. No matter what, the tail lights are interchangeable with the wagons and the panels/suburbans. http://chevy.tocmp.com/chevyresto/3962.htmChevrolet http://www.donsbulbs.com/cgi-bin/r/b.pl/1154~usa.html 1939-COACH REAR-LAMP Automobile 1939-COACH STOP-LAMP Automobile 1939-SEDAN REAR-LAMP Automobile 1939-SEDAN STOP-LAMP Automobile | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I did a google search and think it may be from a 38 & 39 Oldsmobile. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I think these are from a 1938 Oldsmobile http://www.taillightking.com/images/35-50_Olds/37_OLDSIG_Olds_TLAssys.jpgThe 39 Pontiac has a removable base and a neat looking stainless trim that is on the top. When the base is removed it looks similar to the 39 Chevy lights, but has two inline studs about 4 1/2" apart.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yep, they are the ones I have. They fit the body contour perfectly and I paid around $170 for them so I will likely put them on. I need to cut out a rubber gasket. | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I saw this site when I was surfing the other day, and this guy has a bunch of stuff, a lot of repops. But his selection is great. tailightking.com | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Here I'm resurrecting my first ever post. I finally got my lights on. The rear doors will hit them if they are open 180*. I put a bolt in the upper door checks so they don't hit, but I'm surprised that they weren't engineered differently. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Thanks for that bit of info i am just about to install my'n.I am giving serious consideration to mounting them above the beltline. They don't stick out as much and it looks tidy to me. Any thoughts Guy's? Picked them up cheap at www.reidsrodparts.com
layback
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I chose to go another route instead of the "bullets" but before doing so I held the template up to the beltline and it "looked" like the door would not hit them.
Mine you I did not put them on so I do not know but just as a suggestion, Leo, did you use the template or put them where you wanted to?? Not being smart alec here, just trying to help. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yes I used the template, but I have lights from a 38-39 Olds. They are supposedly interchangeable. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1953panel,
Can you post a photo of the mounting side of one of the lamp bodies?
I have original NOS lamps on my Suburban. However, the panel truck's rear-door "stops" are different from the suburban rear-door "stops". The panel stops allow the doors to open wider.
Nonetheless, I am surprised and disappointed to hear that the factory-style dual rear side-lamps hit the rear panel-doors. Let's see if we hear from other 47-55 panel-truck owners who have installed rear side lamps.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Yes I used the template, but I have lights from a 38-39 Olds. They are supposedly interchangeable. I wouldn't say they are interchangeable. 1937 OLDSMOBILE TAIL LIGHTS mount differently because of the mount that they are attached to. That brings them out at a different angle. My guess is that you compensated for the angle and moved it forward on the belt line, thus interfering with the door. But this is strictly a guess, do you have pictures? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .....When I was searching for my "door stops" I noticed there were two that looked almost alike. Leo, are you sure you have the right ones? Again, just guessing. I have a pic somewhere around here of the different versions..... I may have gotten them off one of Tims post??? Like Tim says, my panel doors will swing out so that you could back the panel up to a dock and not hit the doors. Here is a shot of mine if it helps anyone. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/June172009004.jpg | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Those ought to look good on there. I imagine it hits because the holes are different on those from the Chevy ones.
As was mentioned earlier, Burbs don't open that far. Maybe you can round up some Suburban arms. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Alvin and 1953 panel, I sent you a couple of pictures via email that shows the difference between the panel and suburban door checks. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You want to use '39 Chevy car "bullet" tail lights on your AD panel or Suburban. They mount below the beltline. Open the rear doors all the way and mark your installation spot from that vantage point. That's how I did mine 22 years ago ( before they were reproducing those lights) . The '37 Olds lights look nice but the stanchion mount will make the lights stick out further from the body. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I had the mounting holes drilled prior to painting the vehicle. That was several years ago. This week I installed the lights, cannot change the location. I fastened a bolt in the upper door checks so the door opens only so far. Yes, my door checks are identical to Tim's photo. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 |
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Your location of the taillights looks good to me. Do you have the tailgate and not the barn doors? | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | wbrowne, my sub has barn doors.
Weeds | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | |
