4 members (Cletus1950, WICruiser, Peggy M, Greg_H), 55 guests, and 3 robots.
Topics128,172
Posts1,057,108
Members48,463
Page 27 of 177 1 2 … 25 26 27 28 29 … 176 177
Leo Offline
Moderator
Moderator
I got my windows installed, split front windshield and the back doors. Windshield took 15 minutes and about 15 minutes for each of the back doors. I had an auto glass installer give me a hand, cost me $50.
Built brackets to mount the condenser to the fan. Will attempt another run at the rear glass next week.
~Jim
Mounted my p/s gearbox to the frame and started wiring the whole thing. WOW
If it warms up today I will finish the the new steering column and the steering shaft setup. It was -2degrees here last night. Garage is still very cold even with the torpedo heater fired up!
I got the radiator bolted in last night and will start on installing the rear window sometime next week.
~Jim
Finally got the dash off so I could remove the windshield regulator. As I suspected - small worm gear assembly is completely worn out. Rest of the unit is in very good shape. Since my unit will not "core" with any supplier, I will have to repair this one (or fork over $300!!!!). I am pretty sure that I can make any good gear set work on my components. So, the search is on!
Z
Z Offline
I obsessed over pics of the truck looking for the small pieces i need and making a list of items i need and a plan of action for the truck rebuild.
52 Chevy 1/2 ton - work in progress
65 Mustang coupe - work not in progress smile
67 Mustang GT convertibile
67 Camaro RS/SS
We are now even with fords and chevys. smile
Now i need a mopar. Hahahahahahahahaha
installed some new threaded shackle bushings
http://s783.photobucket.com/albums/...%20pickup%20project/?albumview=slideshow
Got the back window in (with the help from my wife). The retainer was a (booger) until I figured out the trick. We couldn’t get the corner window rubber to stay in place to get the window in. Tried tape, ty-wraps, wire, but the corners kept popping out. Then put the window on the bench and ran a bead of weatherstrip adhesive in the rubber and placed it around the window with tape holding it on until it dried. Next day we installed it like you would a windshield (only from the inside out) and it popped right in. Added the retainer and it’s done. Tonight we do the other corner. While waiting for the glue to set I insulated the cab and cut and fit the carpet padding.
More pictures to follow…………………
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Got the ididit column installed, now need to drill some holes to pin it!. Motor mount is in the way to use the set screw, so out it comes again to hit it with the drill press so we can pin it.
Sanded a section of my frame to remove some surface rust. every little bit gets me closer to finishing
Didn't get a whole lot physically done but took the time to make a 'To-Do' list,i've just realised i've still got loads and it's all the little time consuming jobs.
Plus... wheels and tyres next, decisions,decisions.....
More pix on Flickr.
Leo Offline
Moderator
Moderator
Worked some more on my wiring harness, ignition switch is a bear. I also got my headlight buckets and rings on.
I made THE LIST once, very depressing...
~Jim
Z
Z Offline
Ordered a couple doors for the truck. Cheap and in really good condition.
67 Camaro RS/SS
I got the burb home today from a 2222 mile trip. She ran great with a little loss of power above 3500 feet and a lot of lost power above 4500. The arm fell off the brake light switch on the way to Tucson. I was on my way to Mothertrucker Parts to pick up my burb seats so I was able to change the switch there. Then at my last fuel stop today I noticed fuel dripping from the pump. I think the diaphragm is busted.
It was a fun and exciting trip.
Cletis, that's one heck of a shake-down run,glad it was reasonably 'uneventful'.
It's not a fuel leak,it's just sweat from doing all those miles! grin
More pix on Flickr.
Got the last window in. As we went to install it slipped out of my hand, bounced off the side of the truck, hit the tire and then right into a bucket of old anti-freeze I’ve been meaning to dispose of. The window was like a greased pig to hold, but it just almost popped in by itself. I purchased a paint can opener like the article in helpful hints said. It really made the job easy. It worked way better than the tool they sell.
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Congradulations Cletis,
This is what we all look forward to doing someday, SOON!!!!
~Jim
Picked up the tailgate from "Roach" (sign painter). Tailgate looks 100% better with letters painted. Plan to install back on truck this weekend.
Got the 3.55 gears installed tonight and still too much snow for a test drive,the 235 did not like the 2.79 gears so I hope this helps. Had to move the Harley out of the garage to do it and thought I was never going to get it back in.
I DROVE my Bolt today! drive YES
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
That's a fine looking 37 Jeff, but do you really need that tool box on the floorboard? lol
~Jim
After finishing wiring the gas tank, headlights, parking lights, and dimmer switch about 3 months ago and letting her sit like that the whole time..... TODAY I took it to Vintage Rods and Garage to have him finish up the job!!!
I also plan on putting the first coats of spar varnish on my bedwood!!
Replaced the battery, cap, rotor, plugs, fuel filter, pulled out the seat and junk from the box, vacuumed the box and cab. Found 28 cents, 5 mouse traps (all empty) and a Fun Time Arcade token.
I deduced the previous owner was a sheet rocker by the sheet rock screw holding the cup holder to the dash.
Got the alternator installed, roof insulation and headliner, back of cab insulated, new ignition switch and idiot light
Still working on the transmission. Have it disassembled now and will be taking it in for cleaning soon.....
1957 Chevrolet 3600 project truck
and a few Trans Ams.
http://s863.photobucket.com/albums/ab192/3tas4us/1957%20Chevy%20Truck%20Project/
Brushed the snow off of the cover today
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
Speaking of "back of cab insulation", for quite a while it has bothered me that the double sheet metal on the back of the cab resonates with a ton of echos and you aren't able to insulate it. I have been looking at the Touch 'n Seal product for insulation. Has anyone worked with this stuff?
http://www.touch-n-seal.com/company.htm
~Jim
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Last few days tore down the carb. (it is a W1 574S) and rebuilt.
http://s111.photobucket.com/albums/n142/DCINSC/37%20CHEVY%20TEARDOWN/Carter%20W1%20tear%20down/
1937 Chevy 1/2-Ton
Finished fabricating brackets and installing my puller fan and my air conditioner condenser and thermostat. I hope to install rear glass and windshield glass tomorrow. Hopefully I will start it on Saturday. I plan on making videos to mark this, the day 4.5 years after buying it.
~Jim
I bought my 1950 1/2 ton Chevy (Canadian manufactured), and drove it 65 trouble-free miles back to my house.
Pictures to follow.
Cheers,
Fraser
Cheers,
Fraser
1950 Chevrolet 1300 1/2 ton (Built in Oshawa)
http://1950Chevy.blogspot.com
Welcome to the Bolt Fraser. We will be looking forward to those pics. Is it cold up there? Sunny and 63 tomorrow here...
~Jim
today I removed the steering column and wheel. I also unbolted the cab in preparation for a cab removal party tomorrow with the helping hands of other stovebolters.
My Project Bolt
Leo Offline
Moderator
Moderator
Finally got the last two bolts in where the rad support fastens to the fender. My hands are too big to reach through the grill to hold the nut, but my sons gf is so tiny, she managed to get both hands in there. Also put the hood on, but I need to line it up still.
Fraser, welcome to the 'bolt, head over to the welcome centre and tell us more....
We look forward to the pics.
More pix on Flickr.
removed the cab from the frame and got it on the newly constructed dolly. In the process I learned I need to make some changes to the dolly for better fitment and such. Now I am down to a rolling frame. Soon to be heading off to the sandblaster.
My Project Bolt
got my leaf springs sanded and painted
started removing some of the junk that has been added on to my frame over the years.
My Project Bolt
