8 members (DougH6100, Gdads51, Donf, Hanks custodian, FAST55, Gray_Ghost, Bill Hanlon, cmayna),
142
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,950 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | I am 26 years old and really dont know to much about trucks and restoring anything. So I am wanting to know if anyone has any experince on getting the dump bed off a dump truck. Or anyother adivce that I might use on my moster of a project!
Thanks Allen Ind. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | Im 26 myself...Are you referring to the weight of the assembly...?
| | | | | Joined: Sep 2010 Posts: 19 New Guy | | New Guy Joined: Sep 2010 Posts: 19 | The frame and hydraulics for the dump bed were still on the truck when I bought it as well. I had to cut the bed into pieces and lift the sections off with an engine hoist. Harbor Freight often has engine hoists on sale, and I've found that the hoist has been invaluable. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | i guess the other question would be are you trying to save the dump or dispose of it? | | | | | Joined: Sep 2010 Posts: 19 New Guy | | New Guy Joined: Sep 2010 Posts: 19 | I should clarify: I cut the dump bed into pieces because the previous owner had done a terrible job welding it together. It had to be replaced anyway. What's important are the hydraulic PTO and the linkages that tilt the bed. If everything is solid then go ahead and try to lift it straight off the frame... but the weight is going to be prohibitive and the size ungainly. A gantry crane or overhead winch hoist would be best if you've access to a well-equipped shop. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Weight is one of my problems. I want to take it off in one piece. I am the 2nd owner and want to take it back to its glory days! | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | If the bed is metal and I was not going to keep it, I would totally unbolt, disconnect it from the frame and then secure it on the frame with straps. Then just drive it down to the local scrap yard and have them take it off with their equipment. Steel scrap is bringing about $200 a ton right now.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | Brickman Since you want to restore it, can you just leave it on the truck and do your cutting/welding in place? The good thing about a dump bed is, if you raise it up, the frame and axles are almost all exposed. I get nervous working under a raised bed and always triple block it up. Don't rely on the cylinder to hold the bed up if somebody will be under it. 2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | The steel is good on it. It set in shop were I work for most its life. It was used to haul coal to the power plant in the day. Than it sat in the shop for about 30 years. So don't want to scrap it. Just need it off to work on the trucks frame and rear end. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | If you don't have access to a gantry crane or similar, how about calling in a large boom wrecker? The big wreckers usually have a boom arm with a pretty good reach and height, and should be able to easily handle the dump.
I would think it would be fairly cheap, since it won't take long, and they can do it as fill work. Guessing $150.00 or less. And in my experience, the drivers usually get a kick out of "different" types of jobs.
Just an idea.
-Michael | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | I remember someone separating a very large tow truck bed on here using jacks and cribbing to get it high enough.. raised the bed just enough to separate it from the frame then rolled the truck out. Could be dangerous if not done carefully... but i would think its doable.. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | I would second the jack and cribbing. IF you stack everything up securely you can lift it very safely using this method. You can also work on the bed while it is raised and when you are done with the truck and the bed you can simply lower it back down. Just take it slow and plan ahead and you'll be fine.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The dump body is off the truck so if your only removing the hoist now you are OK with your engine hoist. The hoist only weights about 1000 lbs or so and if your engine hoist won't handle that it isn't mush of a shop crane. You'll know before you get the truck out from under it. Another option is to jack it up off the frame and put 4x4 lumber under it from and rear setting on top of barrels, then drive the truck out. I've changed 26' moving vans this way when I first started in the truck equipment business. Necessity is the mother of invention as they say. No money, few tools but lots of need, just be careful and think it thru first. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | I am wanding if a grany crane would handle the weight of the dump bed. I wish I wish could figer out how to put pic on here so you guys could see the truck and the dump bed. To see if a grany crane would work. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | upload your pictures to a photobucket account and then give us the link to the picture.. simple.. | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | Different parts of the country have differnet names for things, So I have to ask, what is a grany crane? I assume you mean a gantry crane or a A frame hoist type of lifting device. However you do it, take you time and think out your plan of action. Pictures of the event would be a great insperation for the rest of us.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Hire a local backhoe/loader to come pick it off and set it on the ground on blocks. Best bet is to have him turn it over so that you can work on the underside which is hard to get to later. If it is a Garwood or similar style then it will have the castings sticking out below the bed. You will need a bunch of chains on hand for the lift and flip. Be very carefull ! | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | When I took the body off the 38 I used the jacks 4x4 and 55 gal drum method. Make sure the ground is solid so barrels don't shift. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | I am getting ahold of a line truck to use to get the bed off. Just hope I can get the pins out easy. Thinking if I take the weight off the bed the pins should come out nice and easy | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | You still may want to consider taking any weight off the pins you are planning on removing and either take them out ahead of time completely or at least getting them good and loose. This way you won't have any chance of a pin not coming out while someone is sitting there waiting for you. Good luck....and as asked for before...if you can get a chance we all love pictures
| | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Ya I still can't figure out how to up load my pictures on here. I would love to show the old girl off to some people who love old trucks. | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | It sounds like you have a nice project there.Be patient you don't want to get hurt ,you'll figure it out. How about a large forklift to get under it.I'd like to see some pics to,but I know how you feel I'm no good at these comp. either. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | Pictures came out good and that is a real gem of a truck you have.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I usually unhook the bed from the hoist, jack it up enough to put some round fence posts under it. Then back one of my flat beds under the edge and winch it into it, using more posts as rollers. Scott | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | Nice truck you have there | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | That is a nice looking truck...looks like it is in great shape. It looks restored compared to mine  What are your plans for the truck? I see you started removing sheet metal. How far are you planning on going?
| | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | thanks! I have always loved my truck from the 1st day I saw it at work. So I was really shocked when I got the chance to buy it off the city I work for because the city I work for never gets rid of anything! Thats why it looks so good it sat in are shop for the past 70 years and really didnt get to see the weather. So I am lucky when it comes to her looking not to bad. I am wanting to take it back to as much original as I can. After I get the bed off I and going to overhaul the engine. I do know that its not the original one. But I am sure that its a 1942,216. Some metal work is needed but not much. Its going to be a nice project I think. | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | definitely a beautiful truck you got there.. good luck with it | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | You have a rare truck there and thats what will make it so special when your done! Does the bed raise with a hyd.cyl. or mechanically? | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Rare? Really? It is hyd.cyl. one thing I noticed that there is no hyd tank. | | | | | Joined: Jul 2004 Posts: 2,990 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,990 | The reservoir is probably built into the cylinder itself. Look for a filler plug near the top end. When you fill it, you need to do it in the lowered position. Or, if it's partially raised, then leave the plug out the first time you lower it. If it's too full and you let it down with the plug in it, you'll blow the seals out of it. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | You might want to check on insurance before putting the dump bed back on the truck. I considered putting a dump bed on mine, but the classic insurance companies weren't very interested in writing a policy, assuming that if it had a dump bed, I would be using it commercially. I decided on a stake body. $275 a year for limited use. With a dump bed I would have had to gone commercial insurance which was around $1,400. It is also at least a ton lighter than a dump body. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Ya I have talked to my insurance company and they were kind of considered with it being a dump truck. But he didnt want to write any thing up on it till it was about restored. So I dont know what to do. I am a big history guy and my truck came from the electic dept where I work so I want to keep it the same. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | Use a collector car insurance co. I have $10000 full coverage for $150 a year!
| | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Ok ya that would work really nice!!! | | |
